19x8 42mm offset = mission impossible ? | Ford Explorer Forums - Serious Explorations
marcinito
Chicago , Illinois
99 sport
http://www.discounttiredirect.com/product/wheels/atsmer.s.xl.jpg
From reasearch that I did I came to conclusion that 19"x 8" with 42mm offset is not going to work unless I go with some kinda heavy duty spacers, which seem to be not worth of hassle right ?
From what I understand is the offset that is going to make this whole deal impossible right ?
Founding the tires that will work is near miracle as well ?
I wish I could get these rims to work ,knowing the price and the look of 'em but again I'm kinda unsure if it's going to work.
btw I'm about to purchase 2003 X-sport 2wd.
Can someone please confirm my concern ?
Those wheels are awesome looking!
Mine are:
SIZE: 20" inch, 20x9
LUG PATTERN: 5x114.3 mm, 5x4.50 in.
OFFSET: +35mm
I get a little rub on the Saleen Sway bar from the tire. Check out BMW X5's for what tire you can get. I know they have some for you. I almost went with 19"s but the tires are a lot more $.
Good Luck and let me know if I can help you out.
If your wheels are 9" with 35mm offset than maybe 8" with 42mm won't be such a bad deal ?
There is something about these wheels that I can't resist. I got 'em for 150 each which is IMO great price.
In worse case I'll just sale 'em.
I'm not concern about the tire price just yet, as long as I can fit 'em with out spacers or anything like that I'm going for it. It's the 42mm offset that makes me worry.
btw your wheels are da best
I have 20X8.5 with 38mm offset with 275/45/20 tires and I rarely get any rub. It only rubs if I am turning tight and I hit a bump. Otherwise no rubs on turns. I have a 97 explorer BTW.
thanks guys , I'm goning to try and see.
Time to look for right tire. :)
