1st gen Batch Fire Injection to Sequential electronic injection swap
Benjam
WI
92 XLT Stick,4x4, 422 cam
The DPFE measures a differential in pressure between the 2 tubes. No vacuum used.
The pressure difference results when the egr valve opens.
Two tubes from the exhaust manifold, just to add.
Benjam :D
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
jd4242
va beach
92explorer&94 ranger
Benjam :D
Im certainly not adding them..I have headers and a custom supercharged setup, dont even have places to add EGR..im sure someone somewhere has figured out how to trick it, just gota do some searching. .
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
The tubes actually connect to the egr tube, not the manifold. Not all sequential fire rangers had EGR either.
jd4242
va beach
I didn't think any pre 95 rangers had sefi except the 94 cali model, which has egr.
Turdle
Habla tortuga
Staff member
Moderator
Humboldt, KS
2000 Mounty
Can you turn it off with a tune? Otherwise, egr only works under vacuum anyway, not during full throttle. It may help your engine last longer. Just a thought.
Using EGR and plumbing for it might be less hassle than trying to eliminate it.
jd4242
va beach
Im waiting on my tuner to call back.but really wanted to do this soon, before new motor goes in and gets tuned..
Im not a fan of egr at all, especially with a inlet where its pre-charger..plus I just dont have anywhere to install one without changing headers and redesigning my charger setup...all not going to happen. .
jd4242
va beach
Found it....;)
http://www.therangerstation.com/forums/showthread.php?t=90610
Before I post anything. .this vehicle did not come with egr and is not required. .check your local laws first!!!
Stock egr system
You basically take the inlet tube of the DPFE sensore and connect it to the output of the EVR..this gives a high reading of vacuum and wont allow it to ever want to open..what this does as far as feul mix or other down sides , I dont know but will get me by till I get tuned..still waiting on a call back to confirm he can remove it from the tune..
2000StreetRod
Staff member
Moderator
Greenville, SC
00 Sport FI, 03 Ltd V8
EGR bypass
Found it....;) . . . I dont know but will get me by till I get tuned..still waiting on a call back to confirm he can remove it from the tune. . .
That was the configuration that I remembered seeing posted a couple times by BobWiersema: Bypass it
The DPFE only measures the pressure differential between the two ports. There is no exhaust flow thru the DPFE. If there were it and the hoses would quickly melt from the heat. Therefore, with the bypass configuration shown there will be no unmetered airflow thru the DPFE and the EVR into the intake manifold to lean the AFR. Personally, I wouldn't take the time to install it. Your tuner should be able to easily disable EGR.
My 1996 Volvo turbo wagon appears to have had EGR at one time but was disabled. I found a crimped short length of the EGR tube still attached to the exhaust manifold. I replaced the stub with a threaded plug. I guess a previous owner disabled the EGR capability in the ECU because I have no associated DTC.
jd4242
va beach
M.
It honestly wont take that long to install. .I would like to get all the wiring done before the new motor goes in..im planning on doing the motor/trans swap in two days so really need all the time I can get..I can only leave the vehicle in the shop over the weekend, then has to be out so deliveries can go out ;)
As you know im sct dyno tuned, its not something I can remove or be removed remotely. .:(
jd4242
va beach
Why not just drive with the check engine light on instead of adding wires to your Ranger engine wiring harness and mounting the EVR and DPFE that you will remove after the tune?
Wont it run in closed loop?? Wouldn't I get horrible mileage and run like crap?? Ill still be driving it for probably a month or two, till motor/trans is done :(
2000StreetRod
Staff member
Moderator
Greenville, SC
open loop?
I assume that you meant open loop meaning the PCM ignores the O2 sensors. That's a good question. Right now I can't think of a reason for the PCM to stay in open loop just because there is no EGR. The O2 sensors are still valid whether or not there is EGR. Your tune is probably a little rich in open loop so your fuel economy would suffer. The main reason I don't like to run in open loop is because of potential damage to my high flow cats.
jd4242
va beach
Opps yea open loop...
Hmm ill have to do some research. I swore I seen it goes into open loop because its used to adjust a/f and timing as well..if it doesnt then I could live with a light..
Isn't open loop basically what it runs at idle at wot anyways tho?? If I would only suffer at cruise then I could live with that also..I do all city driving, its either idle or WOT anyways! !!:D
2000StreetRod
Staff member
Moderator
Greenville, SC
starts in open loop
The PCM is in open loop when the engine is started until the O2 sensor heaters get the sensors hot enough to be reliable. On a warm day my PCM will switch from open to closed loop in less than 30 seconds. The PCM cycles the AFR slightly for several reasons but one is to determine if the pre-cat O2 sensors are functional. If the PCM determines that they are not functional then it reverts to open loop using stored parameters. If the O2 sensors are functional the PCM will stay in closed loop even at idle. At WOT the PCM switches from closed to open loop because the narrow band O2 sensors are not reliable at the rich AFR needed at WOT. The main purpose of running closed loop is to reduce emissions and fuel consumption. I would be surprised if the PCM compromised that purpose by switching to open loop just because the EGR was not functional.
jd4242
va beach
Both my O2s are pre cat stock..but very interesting. .I thought it would run like crap but more I research the differences the more I think ill just run it without the egr stuff and a CEL on..little more research. .
Again thanks for all the help:salute:
Carguy3J
North East New Jersey
'99 4dr. XLT SOHC A4WD
Just like to point out, what you described is accurate for your 2000, or most, if not all 96+ OBD2 vehicles, as they have heated o2 sensors, and tend to reach closed loop status faster and stay in it for a greater percentage of time, then older obd1 vehicles. Its part of why obd2 vehicles generally get better fuel economy. Older vehicles tend to "drift" back into open loop after idling for more then a few minutes, as there is not enough / hot enough exhaust gas to keep the o2 at closed loop operating temps.
Also, EGR flow absolutely has a major impact on a/f ratio and timing. Its why it has such a big effect on light load cruise fuel economy. Given jd4242's unique combo/circumstances, I can kind of see why he might prefer to go without it. But, generally speaking, EGR is a very good thing; particularly if you do a lot of long distance highway driving.
EGR gas flow:
A.) cools the cylinder/lowers combustion chamber temps, allowing for leaner a/f mixtures and more advanced timing without detonating, which more completely burns the air-fuel charge and makes for more efficient operation ( higher mpg ).
B.) replaces combustible fresh air/fuel in the cylinder with un-burnable exhaust gas. It essentially lowers the engine displacement. Less fresh air in = less fuel needed = better mpg
C.) reduces engine output. So, not good at WOT, or under load. However, when you are just cruising down a fairly level highway, you may only need 20-30hp to comfortably maintain speed. So, reduced power output isn't really a factor here . Also, since there will be reduced power output for a given throttle angle, you may need a slightly greater throttle opening/angle with EGR on vs no EGR. This is also a good thing, as it reduces inlet restriction, and therefor reduces parasitic pumping losses. I would say this factor contributes only a small amount to EGR's total benefits, but it helps.
So, as long as you tune for it properly, EGR is something most people who drive their vehicles regularity should want to keep, or even add. EGR is not incompatible with performance, except perhaps in some of the most extreme cases. Personally, I would love to be able to easily add it to my '93 Ranger
jd4242
va beach
Ill agree on a stock daily driven car, especially if long distances are driven, egr is a good thing. anyone that was doing this swap,I would suggest they do try and get all the parts and use egr..gas mileage I would think would drastically improve with the swap
This truck is not..its driven very hard for short distances and or track driven. .egr in this case does me no good.
jd4242
va beach
So will it go into open loop?? How bad will it run if I dont install it for the time being? Would it just run like it does at idle or wot(just rich)??
Carguy3J
That would depend on whatever was programmed into the open loop look up tables, by the tuner. You would have to find out if an EGR failure code triggers the ecm to revert to open loop/limp mode or not. On the one hand, EGR has no function when at idle, under load, or at WOT. However, as someone else pointed out, these ecm's aren't sophisticated enough to determine the exact nature of an EGR failure; only that one occurred. Depending on the failure mode, and whether it results in too much or not enough EGR flow VS what's "expected", it could result in catastrophic engine failure (remember EGR has a big relationship with a/f and timing). So, in that regard, it would make sense for Ford to have "protected" the engine, by having an EGR code trigger a "limp" mode. I don't know. You would need to talk to someone who has extensive knowledge of these earlier ecm's / strategies.
jd4242
va beach
K 1st gen explorers with 4in lift and 31s Modified 1991-1994 Explorers 10
ovrlndr 1st gen explorer 5.5" lift Modified 1991-1994 Explorers 20
T My 2nd 1st Gen Build Modified 1991-1994 Explorers 16
E 1st gen mods Modified 1991-1994 Explorers 21
K 1st gen Upgrades?... Modified 1991-1994 Explorers 4
Number4 2000 Mustang GT Rim on 1st Gen Ex Modified 1991-1994 Explorers 2
Diff Whack Daddy 1st gen sighted Modified 1991-1994 Explorers 1
Rick List of Useful Threads Modified 1st Gen Forum's Best Threads Modified 1991-1994 Explorers 1
S 2nd gen fenders, hood, grill etc... on a 1st gen ? Modified 1991-1994 Explorers 1
C Projectors installed in my 1st gen '93 Limited Modified 1991-1994 Explorers 14
C After Market Bumper for 1st Gen Explorer? Modified 1991-1994 Explorers 8
1 Attn 1st gen guys found cheap body lift Modified 1991-1994 Explorers 0
8 Using 2nd gen AWD T-Case in 1st gen? Modified 1991-1994 Explorers 7
aaron81006 2nd gen to 1st gen hood hinge swap Modified 1991-1994 Explorers 7
B 351c in 1st gen 92 explorer Modified 1991-1994 Explorers 6
K need a 2wd 1st gen engine cross member Modified 1991-1994 Explorers 0
A 1st gen ford explorer lift kit questions!! asap Modified 1991-1994 Explorers 2
9 1st gen lower Modified 1991-1994 Explorers 3
R lifted 1st gen explorer Modified 1991-1994 Explorers 7
K electronic fan on 1st gen... the wait is OVER! Modified 1991-1994 Explorers 11
T 1st gen sas project Modified 1991-1994 Explorers 1
S Wanted: Brush guard that will fit on 1st gen Modified 1991-1994 Explorers 6
jprentice94 The product of my mind 7.3 psd 1st gen Modified 1991-1994 Explorers 40
N 1st gen sport 4.0 possible build question Modified 1991-1994 Explorers 20
L.A.X CARB Certified Intake For 1St Gen?? Modified 1991-1994 Explorers 4
K on the hunt for a 2wd 1st gen engine crossmember Modified 1991-1994 Explorers 5
J 1st Gen 2wd to 95-97 Ranger Brake Upgrade Using 12" Sport Trac Rotors Modified 1991-1994 Explorers 17
E 1st gen 91' explorer MC Brake Upgrade? Modified 1991-1994 Explorers 9
C high speed howling in a lifted 1st gen Modified 1991-1994 Explorers 5
minelson17 Wanted Interior Pull Handles for 1st Gen XL Modified 1991-1994 Explorers 9
F 1st gen to new sport trac seat upgrade Modified 1991-1994 Explorers 6
A Rancho RSX17000 1st gen Modified 1991-1994 Explorers 0
T Front hitch 1st gen explorer Modified 1991-1994 Explorers 4
M 1st gen sas questions Modified 1991-1994 Explorers 7
davy crockett Sport Trac seats in a 1st Gen? Modified 1991-1994 Explorers 4
josh40601 Josh's 4 door 1st gen explorer crawler (SGT Ex) Modified 1991-1994 Explorers 341
C Will a 2nd rear sway bar fit 1st gen rear stock? Modified 1991-1994 Explorers 8
TedJ 1st Gen 4wd to 95-97 Ranger Brake Swap Info/Parts List Modified 1991-1994 Explorers 109
J I Wana see 1st gen ex lifted 4" and 33s!! Modified 1991-1994 Explorers 12
M just bought my 1st gen X Modified 1991-1994 Explorers 18
M Using 2nd Gen Power Roof, In 1st Gen Modified 1991-1994 Explorers 5
J 1st Gen Steering Wheel Replacement Modified 1991-1994 Explorers 6
S 1st Gen EE Sway Bars to be Disco'd.... Modified 1991-1994 Explorers 16
D 1st gen want rear discs Modified 1991-1994 Explorers 7
D Can u swap 2nd gen front axles to a 1st gen Modified 1991-1994 Explorers 10
I Rack and pinion Steering on 1st gen X?? Modified 1991-1994 Explorers 7
S Lifts for a 1st gen? Modified 1991-1994 Explorers 32
davy crockett 6G alternator on a 1st gen? Modified 1991-1994 Explorers 3
ebgb lowered 1st gen alignment... Modified 1991-1994 Explorers 8
J anyone have a pic of this push bar on a 1st gen ? Modified 1991-1994 Explorers 8
Similar threads
