- April 16, 2002
- British Columbia
- 93 4 dr 4x4 manual XL.
Hey guys, I`m changing my clutch out next month. I can`t find a decent write-up here, unless it`s hiding.
I`ve done a few clutch changes in my day, but haven`t done an explorer yet.
I think I am going with a centre force clutch. (BUT)
If I do, I need to decide which one though, they have several, which promise more grabbing power, in increments (30 60 90?).
By the same token, I wheel my Ex, so the clutch would most likely see more slipping, and friction point work than a street truck. I don`t know if the centre force is better in that respect or not, and my clutch never slips on me anyway, so why do I need more grabbing power? would be nice to spend less on the stock replacement kit. (both come with a centering tool, but the centere force doesn`t have a throwout/pilot bearing, apparently)
I have decided that on top of changing the throwout bearing, I will replace the slave cylinder.
I wonder about the rear main seal on my engine. The guy at the parts store told me today that it is a good idea to change it while it`s all opened up.
I`ve never done a seal like that before and wonder if it is harder than it looks, anyone do it? should I heed the "if it`s not broken, don`t fix it" mantra? I`ll string myself up if I replace it improperly and find that it leaks after the job!
Beforehand, I`m going to go to my muffler guy and have him replace the bolts on my muffler system that I will have to undo when I do the job.
If there is any other tips you can throw my way, I`d appreciate it as well.
