1st gen explorers with 4in lift and 31s
Kyleworsham
Montpelier
1993 Explorer sport
Iv looked and cant find what I'm looking for. I have a 1993 ford explorer sport 4x4. I'm looking at the rough country 4in lift and it suggest 31x10.50-15s. I want to see what that combo looks like on 91-94 explorers. Everyone seems to stiff 32s and 33s under them. I dont want any fender cutting and I dont want to have to gear more than 3.73s.
Join the Elite Explorers for $20. Gets rid of the ads!
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
31s will fit stock Explorers.
Check this thread for guidlelines:
And this one for photos...
  • Like
Reactions: ~X~
Kyleworsham
Montpelier
1993 Explorer sport
31s will not fit mine with out extensive triming. My explorer has the plastic rocker panels all the way down the side.
Kyleworsham
Montpelier
1993 Explorer sport
That's another thing all the explorers I see ither didn't come with the plastic rocker molding or it's been trimmed..my Eddie bauer I had only had the rocker trim running under the doors. My sport has it under the doors and runs over the fenders as well.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
Options: remove plastic trim, or run smaller than 31. Or lift higher.
Kyleworsham
Montpelier
1993 Explorer sport
I'm wanting to lift higher. I just want to see what 4in and 31s look like on a un cut explorer..
timtimtimajim
Colorado Springs, CO
1993 Explorer Sport
I’ve got 31’s on about 3” of lift...
It’s definitely possible to fit 31’s with no lift on these. The plastic trim doesn’t really take up much space at all.
  • Like
Reactions: ~X~
Kyleworsham
Montpelier
1993 Explorer sport
That loogs good to me I think 4in and 31s will be good. I like that tire carrier..what did you do for that
timtimtimajim
1993 Explorer Sport
Thanks! I used some 2x3 1/4 wall tube in the bumper. Cut and welded the stock bumper brackets to it so that I could keep the stock bumper. Had to notch the frame the way I did the brackets. Then built a swingout off of that tube!
The link in my signature will take you to my thread. There’s some detailed pictures in there somewhere!
Kain316
Wichita, Kansas
91 explorer xlt 4x4
I have a 91 and have factory suspension. You don't need any lift or fender trim to fit your desired 31s. I have 31x10.5r15s on mine and still have the factory running boards and I have no rubbing at full steer. This is why you see the 33s on the explorer with a 4 inch lift. I haven't had any issues with my current setup.
  • Like
Reactions: ~X~
Kyleworsham
Montpelier
1993 Explorer sport
What I'm looking for is pictures of explores with 4inch lifts and 31s..all 4in lifts for this era ranger and explorers recommend 31s
ovrlndr 1st gen explorer 5.5" lift Modified 1991-1994 Explorers 20
T My 2nd 1st Gen Build Modified 1991-1994 Explorers 16
E 1st gen mods Modified 1991-1994 Explorers 21
K 1st gen Upgrades?... Modified 1991-1994 Explorers 4
Number4 2000 Mustang GT Rim on 1st Gen Ex Modified 1991-1994 Explorers 2
Diff Whack Daddy 1st gen sighted Modified 1991-1994 Explorers 1
Rick List of Useful Threads Modified 1st Gen Forum's Best Threads Modified 1991-1994 Explorers 1
S 2nd gen fenders, hood, grill etc... on a 1st gen ? Modified 1991-1994 Explorers 1
C Projectors installed in my 1st gen '93 Limited Modified 1991-1994 Explorers 14
C After Market Bumper for 1st Gen Explorer? Modified 1991-1994 Explorers 8
1 Attn 1st gen guys found cheap body lift Modified 1991-1994 Explorers 0
8 Using 2nd gen AWD T-Case in 1st gen? Modified 1991-1994 Explorers 7
aaron81006 2nd gen to 1st gen hood hinge swap Modified 1991-1994 Explorers 7
B 351c in 1st gen 92 explorer Modified 1991-1994 Explorers 6
K need a 2wd 1st gen engine cross member Modified 1991-1994 Explorers 0
A 1st gen ford explorer lift kit questions!! asap Modified 1991-1994 Explorers 2
J 1st gen Batch Fire Injection to Sequential electronic injection swap Modified 1991-1994 Explorers 65
9 1st gen lower Modified 1991-1994 Explorers 3
R lifted 1st gen explorer Modified 1991-1994 Explorers 7
K electronic fan on 1st gen... the wait is OVER! Modified 1991-1994 Explorers 11
T 1st gen sas project Modified 1991-1994 Explorers 1
S Wanted: Brush guard that will fit on 1st gen Modified 1991-1994 Explorers 6
jprentice94 The product of my mind 7.3 psd 1st gen Modified 1991-1994 Explorers 40
N 1st gen sport 4.0 possible build question Modified 1991-1994 Explorers 20
L.A.X CARB Certified Intake For 1St Gen?? Modified 1991-1994 Explorers 4
K on the hunt for a 2wd 1st gen engine crossmember Modified 1991-1994 Explorers 5
J 1st Gen 2wd to 95-97 Ranger Brake Upgrade Using 12" Sport Trac Rotors Modified 1991-1994 Explorers 17
E 1st gen 91' explorer MC Brake Upgrade? Modified 1991-1994 Explorers 9
C high speed howling in a lifted 1st gen Modified 1991-1994 Explorers 5
minelson17 Wanted Interior Pull Handles for 1st Gen XL Modified 1991-1994 Explorers 9
F 1st gen to new sport trac seat upgrade Modified 1991-1994 Explorers 6
A Rancho RSX17000 1st gen Modified 1991-1994 Explorers 0
T Front hitch 1st gen explorer Modified 1991-1994 Explorers 4
M 1st gen sas questions Modified 1991-1994 Explorers 7
davy crockett Sport Trac seats in a 1st Gen? Modified 1991-1994 Explorers 4
josh40601 Josh's 4 door 1st gen explorer crawler (SGT Ex) Modified 1991-1994 Explorers 341
C Will a 2nd rear sway bar fit 1st gen rear stock? Modified 1991-1994 Explorers 8
TedJ 1st Gen 4wd to 95-97 Ranger Brake Swap Info/Parts List Modified 1991-1994 Explorers 109
J I Wana see 1st gen ex lifted 4" and 33s!! Modified 1991-1994 Explorers 12
M just bought my 1st gen X Modified 1991-1994 Explorers 18
M Using 2nd Gen Power Roof, In 1st Gen Modified 1991-1994 Explorers 5
J 1st Gen Steering Wheel Replacement Modified 1991-1994 Explorers 6
S 1st Gen EE Sway Bars to be Disco'd.... Modified 1991-1994 Explorers 16
D 1st gen want rear discs Modified 1991-1994 Explorers 7
D Can u swap 2nd gen front axles to a 1st gen Modified 1991-1994 Explorers 10
I Rack and pinion Steering on 1st gen X?? Modified 1991-1994 Explorers 7
S Lifts for a 1st gen? Modified 1991-1994 Explorers 32
davy crockett 6G alternator on a 1st gen? Modified 1991-1994 Explorers 3
ebgb lowered 1st gen alignment... Modified 1991-1994 Explorers 8
J anyone have a pic of this push bar on a 1st gen ? Modified 1991-1994 Explorers 8
Similar threads
