2.0 Ecoboost engine noise when let off throttle
LedZeppelin
South Windsor, Connecticut
2013 Ford Explorer XLT
2013 Explorer Eco with the very same problem.. We have 45k miles and the rattle started roughly 10k miles ago and seems to be getting progressively worse.
It sounds just like a loose heat shield rattle, but I've looked over every heat shield and couldn't find the culprit.
It rattles for the first 1-2 seconds after starting and again (1-2 sec)when you release the throttle. It rattles constantly at highway speeds (with the window rolled down, while driving next to concrete barrier you can hear it).
I've spent the last hour under the car and can't determine the source, but it doesn't sounds like it's "in" the engine. Perhaps something metallic is trapped inside the heat shield??
Before I spend next weekend pulling all accessible the heat shields - anyone have any other trouble shooting methods?
cheers,
Sam
Very similar issue with my 2013 XLT, brought it to the Ford dealer for diagnosis and they determined it was a bad Ecoboost. They suggested not to drive the vehicle as the piece "rattling" could break loose and get sucked into the engine, possibly seizing it. I'd get it checked out and see what the dealership says.
cuonawv
NORCAL
2013 Ford Explorer LTD
Ford dealer confirmed my fears..
Bad EcoBoost - (bits rattling around inside)
Over the past few months we've heard another rattle coming from the front right wheel. We didn't notice any deterioration in steering or control, so we didn't rush to have it checked.. To our surprise it seems the axle nut had backed off causing the additional rattle noise and ultimately leading to significant damage to axle and hub..
Hopefully all is covered under the drive train warranty (fingers crossed)..
UPDATE..
All was covered under the 60k DT warranty.
The EcoBoost turbo waste gate had "failed" with parts of it coming in contact with the fan... Dealer replaced the entire unit.
Additionally, the dealer ended up replacing everything from the CV joint out to the axle nut..
Now we're dealing with the dreaded "Shift to park" syndrome..
All of this coupled with the major leak in the roof joints which left many (MANY) gallons of water trapped inside the body panels are making me second guess our first ever Ford purchase..
Memphis1987
Arlington, TN
2012 Ford Explorer XLT
Possibly experiencing a similar issue?
This is a buzzing noise coming from my 2012 Ford Explorer XLT w/ 2.0L Ecoboost engine. It comes in at the 5 and 7 second mark, right after I rev the engine I bought it about 3 weeks ago (used) with 57K on the odometer. I have not had a chance to take it to the dealership. I just wanted to get some insight from others before I did. I'm hoping someone can give me some idea as to what it might be. Thanks for any info!
Lacajun
Western NC
2013Explorer XLT
Most direct injection turbocharged engines will produce a noise when quickly letting off the throttle. It is the BOV letting the excess pressure bleed off into the intake system.
Memphis1987
Arlington, TN
You're so awesome. I greatly appreciate it. I knew I was probably worrying for nothing but, with this being my first Ecoboost experience and the fact it's an unfamiliar used car...I just needed to make sure. Thanks again Lacajun!
LedZeppelin
I had the same problem with my 13 XLT and it turned out the ecoboost was bad and needed to be replaced, there was something loose and they said if it broke off it could get sucked into the engine effectively seizing it. This was last July, I had to wait almost 6 weeks to get one as they were on nationwide backorder, not sure if the supply has gotten any better this year.
Memphis1987
Arlington, TN
So you're saying that your '13 XLT was making the SAME EXACT noise as my video above...and it turned out to be a bad Ecoboost? I just need to make sure because it's already headed to the shop for the airbag light staying on. I'll mention this if that's the case. Also, if you don't mind, do you remember how much it costed you to replace it? Thanks!
Maverick1986
Charleston, SC
2012 Ford Explorer Ltd
i had the exact same issue at 50k and took the vehicle in over a dozen times they couldn't figure it out. Turns out it was the wastegate impeller broke loose and Ford replaced the entire turbo. Unfortunately it started happening again at 65k miles on the new turbo and Ford told me to **** off they weren't gonna do anything about it. This is an extremely common issue on the 2.0 ecoboost turbo and no recall or TSB has been issued. Many people have just been stuck paying $2500 to replace the turbo.
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
Welcome to the Forum.:wave:
There have been a few posts about the wastegate sticking and it's not just a 2.0 Ecoboost issue. It affects the 3.5L one s well. Don't recall any other posts about turbos being replaced due to wastegate issues here. If you're out of factory warranty and don't have the ESP, I can see why Ford won't pay for a repair. Even if there was a TSB, they are only 'free' while the vehicle is under warranty.
bluehawk27
Location
sf bay area, Cali
CA
2012 Explorer Limited Eco
Hey all,
I just purchased a 2012 Ford Explorer Limited 80K miles with the 2.0L ecoboost engine. Today we noticed that there is a rattle that comes from the engine on cold start(lasts 5-7 seconds) and then again when you let off the throttle to let it quickly rev back down. Any ideas what that might be?
peterk9
Staff member
Moderator
Callsign
VE3
My first guess was that it could be some kind of 'shield'? Heat shield came to mind but it purely a guess.
Please complete your registration by adding the Required/Request "Trim Level" (Base, XLT, etc.) to your profile so it appears in the margin. That can be very useful info to have at times. Thanks.
bluehawk27
Location
sf bay area, Cali
CA
sorry to bring up an old post but was there ever a resolution to this? mine sounds exactly like the one in the video even on cold starts at idle.
bluehawk27
Location
sf bay area, Cali
CA
Turns out the issue was similar to the issue that Led Zepplin faced up above. The car has been at the dealership 4 weeks waiting on a new ecoboost......
blwnsmoke
Staff member
Moderator
Moderator
2020 Explorer ST
What is a new ecoboost. Ecoboost is the name of the motor type. Are you having the motor replaced or just the turbo?
Hebn
Nj
2015 explorer xlt
Has anyone Figured out what the ticking noise is? because I have a 2015 it’s doing the exact same thing
