2-Ball Rockwell explorer | Ford Explorer Forums - Serious Explorations
crazzyearl
Lower Alloways Creek, NJ
The plan
1992 explorer
302 Ho motor
c-6 tranny
205 transfercase twinsticked
Rockwell axles one steering one fixed (4ws some day)
Four link front and rear with the back half of the frame hacked off behind the passenger seats and tubed out.
Parts curently gathered
rockwell axles
DIY4X pinion brake kit
302 HO
C-6
2-44" boggers 2-44" tsl's
4 used 16.5 rims for rockwell patern
explorer body and frame
205 transfer case
enough about what I WANT to do and time to start with what i am doing
I wheeled that big ******* into the shop to begin tear down.
Soaked every nut and bolt with pb blaster fo a few days since the axle had been seting outside for a few years.
Tore the axle down to pull out the shafts. This picture was moments from dissapointment.
Thats not a U-Joint!
None of that junk is going back on the axle ill keep the shafts for emergancy spares the a junk yard close by that sells the u-joint shafts for 220 a side so ill be geting them when the holiday bills are paid off.
Started shaving the rockwell pan
fliped them over and covered the gears to gring and cut the ends even and square
welded on the plate to cross over the bull gear
got a little work left to do but you can see the shape im going for
finished my shave today
then i removed the old seal and spacer. Got the new seal spacer combo from custom off road to change over from the rapeeze to the u joint
Poor truck has no idea what is instore for it
put the center section back in a filled my diff with oil to be shure the shave didnt leak
put the kuckels and boots back on hard to do by yourself
cheaked for tire and rim clearance
Almost done with this axle for now till i order the steering that will wait till i get farther along with the rest of the project
Im loving this man. I have been wanting to put a set of rocks under my X for a while. I still fell i will some day but not now.
I am in for the progress on this explorer. Keep it up.
daaammmm......
...I too am in for the build progress...:popcorn:
nice clearance
