2 or 4 inch lift... help me decide please
Caleb Teague
Kansas
'94 Explorer XLT 4dr 4x4
Gonna be getting a lift when I put new rubber on the 94 exploder, which shouldnt be long now as I have 7/32 left on the ole goodyear wrangler radials.
Now, I hope to just do a suspension lift, and I'm trying to decide between 2 or 4 inches.
I have stock 3.27 gears (yikes, I know), and I plan to go either 2" with 31s or 4" with 32-33s. I'll be keeping the stock wheels, and I'm ok with doing a little trimming, but nothing too extreme. This truck doesent see any super aggressive off roading, but some mud fairly frequently, and snow in the winter months. It's a daily driver so I am hoping to not mess up handling too much.
Now, I know a 4" is much more extensive than a 2 inch, involving drop brackets and new brake lines, new springs and shocks. I need new shocks and springs anyway, so a simple coil spacer and shackle lift is out of the question. This is the only reason I consider a 4" lift.
My main reason for lifting is a more aggressive look, and a truck to be proud of. The tires help with the mud, of course.
I'm lookin at this: 4in Ford Suspension Lift System
What do yall think?
Mbrooks420
High Voltage.
EF Vendor
1998 Mountaineer AWD
Gears first. 3.27 and oversized mudders are asking for trouble, especially with the auto. Get a complete 8.8 out of a yard and swap it in(2nd gen gets you rear discs), and swap in a used front diff.
RangerX
Elite Ranger
Staff member
Moderator
Omao, Kauai
'93 Ranger XLT 4X4
I second that. Assuming you have auto trans, that gearing and any of those size tires will be quick death for your trans.
Caleb Teague
Kansas
Alright, I was hoping to avoid that, though. I'd like to just do new ring gears and pinions with 300k miles on her it may be in order anyway. What's the largest I can go on those 3.27 carriers? I think it's like 3.58 or sumthin like that. Yall recommend larger? I've seen people say go with 4:11 if you change gears, but 4:11 donors are hard to come by, and I dont want to destroy highway mileage as most of my driving is 45+
Thank you for the input thus far :)
Mbrooks420
High Voltage.
EF Vendor
4.10 is the best of the factory gearing. 3.73 would be much better as well. You could get a traction lok unit and rebuild it before dropping it in. I’ve seen several 8.8s on CL fairly cheap.
I’d also add a large transmission cooler.
Caleb Teague
Kansas
Hmm, yall are making me think that I should just throw some new rear springs on it to fix the lean, new coil over shocks on the back for towing, and some meatier tires for the aggressive look I'm after, and leave it as is. Seeing as I'm not even doing any real offroading, a lift isnt nessacary. Regearing, even if I get a new axle in the rear, I'll still likely have to regear the front, and that's alot of precise work so they don't grenade, that I'm not sure I am capable of.
I think some nice tires and some new springs is what's gonna suit me best, thanks guys, this is why I came to you. :chug:
Nadams01
Castle rock, Colorado
1991 explorer eddie bauer
Here's mine with a 2" lift up front, lift shackles in the rear, and 31's.View attachment 180137
I was looking into doing a 2 inch lift because I picked up a good set of Rancho rs5000 series shock for 2 inches. I was nervous only 2 inches wouldnt add enough clearance or agressive looks but it looks great on 2 inches. My leaf springs are sagged out hard so il be doing new ones from s.d springs with the drop shackles and 2 inch springs up front from s.d springs
Gazios
Wa
87 Bronco II, 4.0L
Caleb:
I put full deal 2" suspension lift on my Ranger and 4" suspension lift on my BII. They both work great. With 4:10 gears my engines like 32" tires to put the torque curve where it drives like the original vehicle.
32's with a 4" lift would be close but with the Ranger I needed a body lift and fender triming for 32's and definitely for 33".
In regards to ride quality my 2" is a Ford factory suspension lift from an 89 Hi Ryder Ranger, it is very stiff; the 4" lift is and always has been an absolute pleasure to drive. Though with a BII as with an Explorer, body roll rates definite control messures. To which James Duff Enterprises has the best solution I have ever experienced.
They make dual shock hoops for the front and dual shock track bars for the rear. Using dual Duff 70/30 valved shocks, virtually eliminates any body roll! In my opinion this is the best money spent on suspension for an Explorer or BII.
imsick247
Long Beach, CA
1994 Explorer Sport 4x4
My 94 has 4" lift, 3.73 axles and and 32" tires.
I definitely recommend bigger gears if going with tires bigger than 31".
4" lift with 31" tires doesn't look right, so gears are my next upgrade.
Best bet? 2" lift with 31" tires and 3.73 gearing.
fordpickupman
Cascade, ID
94 XLT
71 F250 Fummins
I ran 3.27s with 33s for a year. Then I ran the 3.27s with 35s for 6 months. I swapped in 4.88s a couple years ago with Trutracs and love them. If I was going to do it again I would go with the 5.13s and a true locker in the rear. The trutracs are super smooth though, you don't even notice them on the ice, it just keeps going.
imsick247
Long Beach, CA
Save up for new gears!
F 4 inch lift help needed. Modified 1991-1994 Explorers 3
1 Is 5 inch lift on 94 explorer enough for 34's? Modified 1991-1994 Explorers 13
B 4 inch lift + soa Modified 1991-1994 Explorers 9
K looking for 4 inch lift leaf springs Modified 1991-1994 Explorers 10
A 2ish inch lift questions. Modified 1991-1994 Explorers 10
Jim wright Want to put 35s underneath my Ford Explorer got 3 inch body lift Modified 1991-1994 Explorers 5
E 2 inch lift questions Modified 1991-1994 Explorers 17
J 1991 exploder 4 inch lift. 4x4 problems Modified 1991-1994 Explorers 7
HSlough 4 inch lift? Modified 1991-1994 Explorers 20
M Rancho 2.5 inch lift install directions Modified 1991-1994 Explorers 11
N 1993 ford explorer 2 inch lift, what backspacing for wheels? Modified 1991-1994 Explorers 20
C i have some ? about steering after a five inch lift. Modified 1991-1994 Explorers 7
9 3 inch suspension lift Modified 1991-1994 Explorers 0
G 2 inch lift and dunes Modified 1991-1994 Explorers 4
A Quick question 4 inch lift Modified 1991-1994 Explorers 16
A 4 inch lift question (s) Modified 1991-1994 Explorers 6
V 1.25 inch shackle lift and 2 inch front spacers Modified 1991-1994 Explorers 4
T 3/4 or 1 inch body lift? Modified 1991-1994 Explorers 8
M 2 inch lift..parts Modified 1991-1994 Explorers 6
J 9 inch lift Modified 1991-1994 Explorers 12
9 6 inch suspension lift advice. Modified 1991-1994 Explorers 3
9 i got a 6 inch fabtech lift tell me if got everything Modified 1991-1994 Explorers 27
S 4 inch rough country lift Modified 1991-1994 Explorers 4
C Putting on a 3 inch body lift. Modified 1991-1994 Explorers 35
DUDER 1 5.5 or 6 inch lift with 35" tires pics. Modified 1991-1994 Explorers 29
J want to do two inch lift Modified 1991-1994 Explorers 4
J 2 inch lift Modified 1991-1994 Explorers 1
F Steering binding after 3 inch body lift Modified 1991-1994 Explorers 6
red.EDDIE.4x4 add-a-leaf? SOA? or 4 inch lift leafs? Modified 1991-1994 Explorers 13
T Suggestions for a 2 inch lift on 94 Explorer Modified 1991-1994 Explorers 30
T 6 inch front lift for under $500 Modified 1991-1994 Explorers 34
N 4 inch lift??? Modified 1991-1994 Explorers 13
Hossexplorer 2 inch lift on 93 X-pics? Modified 1991-1994 Explorers 38
1 4 inch lift and 33x12.50 Modified 1991-1994 Explorers 38
Hossexplorer '93 explorer 4 inch lift..Any advice? mpg? Modified 1991-1994 Explorers 31
B 2 inch lift need shocks Modified 1991-1994 Explorers 0
1 4 inch susp. lift Modified 1991-1994 Explorers 37
S 2-4 inch body lift anyone? Modified 1991-1994 Explorers 16
1 4 inch lift 33x12.50? Modified 1991-1994 Explorers 1
1 4 inch trail master lift Modified 1991-1994 Explorers 1
Four0Sport question for those with a 4 inch lift Modified 1991-1994 Explorers 2
9 2 inch lift pics with or without body lift Modified 1991-1994 Explorers 1
9 any one got pic of two inch lift only Modified 1991-1994 Explorers 3
R 3 inch body lift question. Modified 1991-1994 Explorers 9
P 2 inch lift kit Modified 1991-1994 Explorers 20
M 3 inch body lift Modified 1991-1994 Explorers 4
T will 22 inch rims fit without a lift Modified 1991-1994 Explorers 16
T 3 inch body lift stearing extension SOLUTION Modified 1991-1994 Explorers 2
L 1993 Eddie Bauer - 31 Inch tires?? Modified 1991-1994 Explorers 14
T 31 inch tires Modified 1991-1994 Explorers 13
Similar threads
