2 piece uca on drivers side??
matth
frederick, md
01 2wd sport
Has anyone heard of using a passenger side 2 piece upper control arm on the drivers side of a tbar truck for a little more adjustment?
Join the Elite Explorers for $20.
Explorer Forum has probably saved you that much already, and will continue to save you money as you learn how to diagnose fix problems yourself and learn which modifications work without having to experiment on your own. Elite Explorer members see practically no advertisements, no banner ads, no double underlined links, can add their own profile photo, upload photo attachments in all forums, and Media Gallery, create and save more private Conversations, and more. Join Today. Your support is greatly appreciated.
corkey
Moderator Emeritus
Moderator Emeritus
Location
Sioux Narrows Canada
Elite Canuck,multiple ifs offender,, and musky maniac,, i wheel and i fish,,
99 xls,96 xl,91,08 Ranger
either that or use the cheaper camber bolts,
they adjust both caster and camber with the bolts,,
on my 99 there are 1 piece arms on both sides, and it aligned very well,,
the bolts are the key ,,
corkey
Moderator Emeritus
Moderator Emeritus
Location
if you're talking about on top of having the bolts,, i say that it is not really necessary ,,
not saying it can't be done, but it means adding another variable into the system,
making an alignment maybe harder to do,,
or maybe easier, as it could be used to adjust the caster more easily,,
check with the people that do your alignments , ask them about which way they would want it
unless you do your own alignments
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Ditto corkey. No TWO piece UCA exists for the driver side. Your '98 should have come stock with the two piece passenger side UCA unless it was replaced. Benefit of using the one piece arm is getting new bushings and a stronger design. Even if you want to go back to the original setup you would need buy and install the upper piece unless you still have it. Many have installed the passenger side one piece arm with camber kits and achieved perfect camber and caster.
http://www.moogproblemsolver.com/_pdf_en2/DYK10_106_En.pdf
matth
frederick, md
01 2wd sport
I understand that the camber kit will do the job. I have them, they work great. The question stands. Will a passenger side 2 piece uca work on the drivers side. I think I read that the low rider boys do this?
