aveteam
- January 16, 2021
- Lakeview, OR
- 2000 Explorer XLT
Hello all, this actually happened a few months ago but due to a house renovation I'm just now able to do some troubleshooting.
Like the title says, we were going down the highway when out of the blue, it just died like someone cut the ignition. No noise, no warning, and it had been running like a champ up till this. When I tried to start it, it would fire a couple times, but wouldn't completely start. We had just gassed up about an hour earlier. Had to have it trailered home. My first thought and fear was that the timing chain(s) had finally let go. After thinking about it, that seemed less likely because there was no noise or anything, it just quit. I checked the inertia switch, and that wasn't it, it wasn't tripped. I tripped it, and then it wouldn't even try to start at all.
As part of troubleshooting, I unplugged the MAF sensor and it would actually start and run for a few seconds, slow down, lope and then die. This is repeatable, and when reconnected, it goes back to not starting. It does have some fuel pressure because I bled off some from the Schrader valve in the fuel line into a rag. Unknown how much pressure, but a fuel pressure test kit is on the way. I've checked the crank position sensor per another thread that suggested using an OBD scanner to check for engine RPM while cranking- it does register some RPM while cranking and when it's running, so while I guess it doesn't rule it out completely, it does make it less likely.
At this point I'm suspecting either a faulty fuel pump or a clogged filter, but none of the threads I've read here are close enough to what happened to it to give me a decent idea of how to proceed. So I figured I'd come here and lean on the expertise in the forum.
