2000 5r55e front transmission leak | Ford Explorer Forums - Serious Explorations
jr14ford
west newton
01 ford explorer xlt
I have changed my front pump seal and converter seal and it still leaks fluid out of the front what else could it be
Sometimes the bushing behind the seal will spin or move out of place and if it walks forward enough it can contact the seal which will cause the seal to leak.
The converter itself could have a crack, I have seen the weld for the hub and the hub crack, the studs I have seen leak where the are welded to the cover.
thank you very much I will pull it out a third time and really look at it this time never had a leak I could not fix by changing front seal
