2000 5r55e Tranny's | Ford Explorer - Ford Ranger Forums - Serious Explorations
2000 5r55e Tranny's
Daniel72221
Alvin
2000 Ford explorer XLS
2000 explorer XLS . 5r55e. Don't know what solenoids go to what. With ignition on not running one coil getting warm. Insulation 6 or so inches away I can see where insulation got hot got hard and cracked and now sits in fluid. Don't know if that itself is issue . Have to manually shift from 1st to 2nd then drive which rpms then go up. Then turn off OD and it will then hit upper gears. No reverse. Barely moves. Haynes book ain't helping any more than it has. Old School, just learning electronic motions of the shifting. Anyone have time to teach?
drbenz
High Point, NC
2000 EB 5.0
One of the finest sources of trans fixes and info:
In this case type in 5r55e in the top left search box (search by title).
Flashflood
Location
Laramie
Wyoming
2000 ford explorer ltd
Do the separator plate while you're in there. Unfortunately I'm having issues with my 5R55E too. Be careful with the valve body I just replaced mine with a nice reman and I'm having worse issues
JK080
Transmission Moderator
Staff member
Moderator
North Ga
05 F250 6.0
No reverse and no drive unless low and 2nd and or OD off is a sign of a broken input sprag. Input sprag is located inside the transmission, it will have to be rebuilt to fix this issue.
