llTheSystemll
- February 1, 2025
- Guntersville, AL
- 2000 Explorer Eddie Bauer
Hi Everyone,
I thought I had the answer in this thread:
www.explorerforum.com
I removed the Blend Door Actuator from my wife's 2000 EB Explorer with EATC and it is labeled:
F87H-19E616-AB
R242 A31991
ATC
Before I did any research, I called my local Ford Dealer to see if they can get a F87H-19E616-AB and they said they could not and did not offer any suggestions other buying a Dorman or an aftermarket replacement which I will do if I have to.
However, the thread above says that this part is the replacement:
F87H-19E694-AB
236 11249122
ATC
If F87H-19E694-AB is indeed correct then I may be able to get one BUT ...
During my research, I found that the Motorcraft YH-1761 is also a replacement. I called the dealer back, got another person in parts and asked about Motorcraft YH-1761. This person said that they cannot that part either but confirmed that the Motorcraft YH-1761 will fit in my wife's Explorer. One thing I forgot to confirm with the parts person at the dealer was if it was EATC or manual. Online says it is EATC. Is this correct?
I did ask the dealer if they had the Ford # that went with the Motorcraft YH-1761 and I got this part #:
F87Z-19E616-AA
He said it fits
1998-2001 Explorer
1998-2002 Ranger
Mountaineer (i did not get the years)
So if I can find any of the following (that work,) will I be ok?
F87H-19E694-AB
F87Z-19E616-AA
Motorcraft YH-1761
What got me started was that the air was always cold and never got warm. I never heard any clicking.
My research also led me to do the following:
Run the Self Test (Off/Floor then Auto within 2s). I did it 4 times. I got 024 then 025 on the 1st test then just 024 on tests 2-4.
Removed the Actuator. I cleaned the pad underneath the gear (semi-circle), cleaned the electrical connections, slightly crimped the ends within the connector.
Pull Fuses 10 and 36 for at least 2 minutes.
After this, I connected the Actuator up to the connector and retested. I got 888. I tested a 2nd time and again 888. I did not think to test it after I initially removed it to see the results. I should have.
I could see the Actuator 'post' moving during these tests. I then put the Actuator back with no screws. 3 self tests passed. I then screwed in the 2 front screws only. This time I could hear clicking and back to 024. I tested again and got 888. I gave up for the day and put my battery on charge. The next I tested again with the Actuator out and got 888 on all 6 tests I did.
So it seems that it works but when installed it is hit or miss. I guess the gears are close to being totally worn out.
So even if I could get a Motorcraft even a manual one for the right price, maybe I can just swap the gears?
Is there a 'start' position that I need to know about? When I initially removed the Actuator, I noted the position of the post so I could re-install it. The post was at one extreme but I noticed that when I did the Self Test with the Actuator not installed but connected to power, the post went to a position about mid-way (75 Degrees F maybe). I had to 're-align' the post by starting the Self Test and when the post got to the position it was in when I first removed it, I turned off the key or I pressed the Defrost button (I forget which ATM). I could then re-install it.
In a perfect world, as long as I can align the post and install the Actuator, does the Self test take care of the rest (whatever that might be)?
I know this is long winded but I did try.
Brian
2001 Explorer EB ATC Blend Door Actuator confusion
Ok, sorry to bring this up again, but... It's supposed to get into the mid 80's this week in GA and I've decided that I should go ahead and replace my stripped blend door actuator (auto-temp-control/EATC 2001 Explorer Eddie Bauer 5.0L w/rear air). In redoing my previous research I again find...
F87H-19E616-AB
R242 A31991
ATC
F87H-19E694-AB
236 11249122
ATC
F87Z-19E616-AA
He said it fits
1998-2001 Explorer
1998-2002 Ranger
F87H-19E694-AB
F87Z-19E616-AA
Motorcraft YH-1761
Brian
