SteveK1014
- June 19, 2011
- North Highlands, Ca
A really great site and wonderful service . I have a 2000 Explorer, the AC compressor cycles at about 2 second intervals at idle - 2000 RPM. The ambient outside temperature is 95 degrees F. The 134R static pressure is 110 lbs, air from inside vent is 70 degrees F - AC on Max - blower one position under full, car windows down. Compressor low side goes down to about 28 lbs and cycles off - high side increases to 190 lbs before compressor turns off. When compressor is off, low side to increases to 50 lbs and high side drops to 155 lbs. I have not yet driven the car on the road to check temps. Does anyone have any thoughts or suggestions, I appreciate all reply's Thank You.
