dz
- November 19, 2007
- Lower Bucks, Pa
- 97 Sport 4wd
Check engine light and code P0455 appeared about 3 months ago. Replaced the fuel cap, code went away for about 2 tanks of gas (which took about 3-4 weeks as I don't drive it much). It has come back and has not went away. I used my buddies Blue Point scanner to clear it again. I did the basic looking for fuel leaks and such. I had it up on a lift, while underneath the truck in the rear I can faintly smell raw fuel. While it's on the ground I don't smell it. Is there anything I am missing or specific things I can check for, or a commonly repaired item for this? Thanks in advance.
