astanford
- November 24, 2013
- Kansas
- 2000 Explorer Sport 2WD
Hello!
I have a 2000 Explorer Sport 2wd, 4.0 OHV.
I recently had my drivers front wheel bearing go out at 30mph, It literally welded the washer and outer bearing to the spindle and after 12 hours of beating with a hammer and chisel, and using a hacksaw I was able to get it off and replace the Inner/Outer bearings and races, New washer, new seal and of course smother it in grease, the spindle had a small dink but was able to smooth it out with some emery cloth. I torqued it down to the initial 25lbs and backed it off half a turn and then torqued it 20lbs as seen in a post on this forum. The wheel was snug and no play what so ever and it spun freely.
On to the test drive, Since replacing the bearings on the drivers side my car now pulls insanely hard to the passenger side, Can go around a 45 degree turn by it self almost, And when braking its the same, Pulls hard to the right.
(not sure if this is due to when the bearing went out it nearly put me in the ditch it pulled that hard to the left, Maybe it messed up alignment? not sure?)
I took it through some S curves and when going through a left handed curve I hear a popping/clicking sound coming from my front drivers side, But only when going into a left handed curve at 35 mph or more.
Any help would be greatly appreciated so I can get this problem taken care of ASAP, I will be replacing the other wheel bearing on the passenger side next week as I'm sure its getting worn as well, just didn't have the money to cover it this week.
