MostlyNewExplorer
- October 22, 2016
- 2000 explorer Sport
The vehicle in the title. 5R55E Transmission. First I had the OD light blinking every now and then(for a long time) then the trans started to slip a little when I first put it in gear in the mornings, but was fine once I got going, so I added a little ATF, and all was well, then it started again, and eventually it started slipping more. The last day I drove it, the trans started to slip really bad, so I gave it a lot of pedal and it kicked into gear, but it wouldn't go into all 5 gears, it would shift from 1st to 2nd to 3rd just fine, but wouldn't upshift any further.
To make a long story short, I replaced the transmission with another 5R55e, now it won't upshift out of 1st gear while in Drive. So I'm running high rpms, but it's not upshifting. If I let off the gas and get back on the gas the trans slips and I have to rev the engine a little to get it to engage.
Could this be the shift cable out of adjustment? Or is it possibly a solenoid issue? Or something else?
This is a 4x4 BTW
Thanks in advance for any help.
This is a 4x4 BTW
