joe doe
- April 10, 2003
- slatington,pa
- 2000 ex sport 4.0 ohv
ive done all the reading ,and ive done the checking .seems this most likely to be the rear abs/speed sensor.......i checked them all ...the 2 front were 399 and 412 ohms ...the rear i couldnt get no reading at all.but my speedo still works ,this sound right??what should i actually ask for?speed sensor or rear abs sensor?i,m calling ford in the meantime.when you install the new one can you dip your finger in the diff to nab a little oil to lube the oring?i cant see buying the stuff just to lube the ring.answer what you can .thanks guys.....joe
