mmmmedic50
4x4 manual trans
- September 19, 2016
- Location
- NE Indiana
- Garrett, Indiana
- 2000 Explorer Sport
I bought a 2000 (8/2000 build) Explorer XLT 5.0 as a donor vehicle for the 5.0 engine. I'd like to get the engine running before I pull it to make sure its OK. 92K miles. Before I got it it had been sitting for a 3 years and the lights and speakers had been removed. I don't see any wiring harness damage. All of the fuses and relays had been removed. I replaced all of the fuses and relays and put a good battery in it. When I turn the key and crank it, it builds oil pressure and cranks good but won't start. I do not hear the fuel pump pressurizing. I have noticed the THEFT light flashing rapidly after cranking. Flashing codes appear to be 16. I think that means the PATS system is not talking to the PCM. I bought the code scanner OBDlink MX and it says it can not connect to the PCM. I used it in another known good vehicle and it connects as it should. I have checked the fuses and relays and believe they are good.I think I need to confirm that the PCM is good. How can I accomplish this? Thanks, Michael
