firefighter1
- March 4, 2012
- Midlothian, VA
- 2000 Ford Explorer XLT
I have a 2000 Explorer XLT with A4WD. The 4wd will not automatically engage when wheel slippage is detected. It will operate in 4 wheel high and low modes properly but not in auto mode. I can literally do a burnout with my right rear tire and the 4wd will not engage automatically. I haven't actually tried to force my left rear tire to spin on purpose but I believe it will. I don't think both rear tires will spin or burnout at the same time. I do know when on a wet surface and on a slight curve on a on ramp, that the back end will slip out and I will start drifting. Explorers don't drift well on wet pavement.
I did replace the transfer case about 4 months ago or so. About 5-7 clutch discs had disintegrated and it was staying in 4wd high and wouldn't come out. It was replaced with a used transfer case with matching numbers. The only difference was that the new/used case had a counter weight on it where mine did not and a lot less miles on it. Also replaced pinion seals and u-joints at the same time. AllDATA is no help with this unless I want to ohm everything. I am thinking possible a sensor on the transfer case but that will be hell to replace. The transfer case has to come apart for those sensors. The system did work before I replaced the transfer case but I can't say I remember it engaging automatically after the swap. Then again I had no place to test it at the time and didnt think much of it with the high and low working. Any ideas or thoughts anyone? I do have another GEM module but the numbers arn't matching up. Mine says XL2T-14B205-CD with the large C and says sport utility automatic A4WD at the bottom. The other one says P1F87B-14B205-CC with the big C and it says sport utility automatic 4WD at the bottom. I think it may have come out of a 98 explorer.
