LegionDirtCrew
- June 4, 2020
- Somerton
- 2000 ford ranger EDDIE B
Hello i am new to this Forum and looking for advice from y'all gurus.
I bought a complete 2000 explorer 4.0 sohc eddie baure eddition 2wd.
-I will be doing a complete motor, trans, PCM and harness swap from this explorer to a 93 Ranger and looking to get away with not using the steering column off the explorer on my swap which includes the gear display and key switch. The ranger is an off-road truck and has aftermarket dash and autometer gauges with an aftermarket key switch. Only thing stock on it is the 4.0 ohv and manual trans with the harness and ECM.
-I have sent my PCM to get tuned and have the PATS deleted. Does anyone know if getting the PATS deleted will eliminate me from using the everything on the steering column? The neutral safety switch, a purge sensor for emissions, purge valve solenoid, all 4 doors were removed prior me buying the whole thing.
-Hoping to remove all the emissions or bypass. Maybe the tuner guy can help me with that. Any ideas? This is for a off-road truck and the less crap from the swap the better but i dont want it running rough ither.
-Is this the gen that it wants to automatically shift on its own? Wanting to do a aftermarket shifter like Art Carr or B&M which I read a thread on it here.
*Also looking for recommendation on a shifter kit that helps this OEM tranny run alot better. From what I heard there are a few flaws with what i believe is the 5r55e and somewhere read about a shift kit to make the tranny run better and smoother.
