laney1968
- October 7, 2004
- Little Rock, AR
- 2000 Explorer Sport
My Sport is going hay wire. The CEL is on and the codes are both bank 1 and 2 are too lean. Took it to the mechanic, he replaced one Oxygen Sensor. Told him that the idle was rough and when I came to a complete stop, the truck acting like it was going to die. He said BAD GAS, put Alcohol in the tank to absorb the water, which I did. Drove the truck about a mile, and the RPM's took a dive, the truck sputtered all the way to Autozone. The CEL was back on, gave me the same two codes. On the way back, the truck acting like it would die and it was getting no gas, eventhough I had a full tank. Finally, it did die and would not restart. Had it towed back to him. He changed the fuel filter and cleaned the MAF, said it was ready to go. Got back in it, and it started running rough again. He said the TPS was shot, but he couldn't get a code on his $5000 diagnostics machine. Should I let him replace the TPS?
