tbirdman
- June 22, 2003
- Sask- Canada
- 2000 Sport 4x4 4.0 SOHC
Take care everyone.
Addendum:
Note to all - after installing these step bars/running boards I was concerned about the number of unused bolt holes in each step bar. Each hole has a factory installed nutsert designed for use with the enclosed 8mm (M8) step bar mounting bolts. With four step bar mounting bolts used to mount the step bar to the existing Explorer Sport step bar mounting brackets-there remained a total of 8 unused mounting bolt locations per step bar and each of these had an M8 nutsert. Now-it's only a matter of time until water,road salt,mud etc. will find its way into these unused mounting bolt locations. And then - yes - once inside the step bar tubing - start rusting from the inside out. So - I purchased some M8 x 10MM set screws from a local hardware store (I needed 16 set screws - 8 per side). After removing the step bars- I coated the unused nutserts and the set screws with clear GE Silicone II and threaded them in. After some clean up & drying time - the step bars were mounted back in place and now we are ready to go. Now - I know it's not completely sealed up as the end caps will allow some moisture in - but it is certainly better then it was. I have enclosed a pic of the cap screw used. You could also use an M8 bolt- but I wanted to keep the step bar surface clean.
