CyanideSandwich
- July 28, 2019
- Suffolk County, NY
- 2000 Ford Explorer Sport
Hey, new member so sorry if anything is missing. I have a 2000 Ford Explorer Sport, and recently i've been having an electrical issue. This past wednesday I went to start my car, and when i turned the key everything came on, but once i tried to start, everything died and shut off. The engine didnt even attempt to turn, turning the key to ignition was the equivalent of taking the key out. Had to get a jump start from a tow truck, car started right up no problems, drove home.
I tried reconditioning/recharging the battery, no dice, same symptom. Got a battery replacement today (sunday), and when I went to start the car, same thing happened, everything died upon trying to start. Ok, maybe battery needed to be charged up, put it on a 8amp charge for a couple hours, this time when I went to start, I heard the engine attempt to crank for a split second before again, everything shut off. Put the battery on a 2amp trickle charge for the night, and here I am.
My question, if it's not the battery, what else could it be? Is it a bad starter? I don't even know if starter can just spontaneously fail like that, with no warning. Right now i'm thinking there's corrosion on one of the wires somewhere, but i dont even know if that could be it. Has anyone else had a similar problem, or at the very least could give some direction what you would think this could be
