Replacing my upper ball joints!
IF anyone wants a how to do this let me know and i will post one in here.
with the assitance of a friend from work we replaced my upper ball joints on both sides. i knew they were due because the alignment shop told me but little did i know they were this bad. they were so far gone that im surprised they didnt blow up.
This is the drivers side as you can see its PRETTY GONE!
Passanger side with literally no pressure on it.
So this project took be about 5 hours. the drivers side took 4 hours, we had a lot of problems because there is so much stuff on this side and its hard to get to bolts. we ended up having to cut the bolts on both sides, and we had to cut the left side end because it would not come out. This ended up causes a smidge of a fire!!!! oops
as you can see we had to cut it up quite a bit.
and the passanger side took a total of 45 minutes. so much easier cut both bolts pulled out put in boom done!
this pic is of some of the smoke after the doors being open for a while.
So next project is either lights/ HIDs.... or tires/ rims. just got to get the car sold which hopefully i will this week!
