barneyhyphen
- February 11, 2008
- Nashville, Tn
- 1999 Explorer EB 4.0 SOHC
Could someone please advise me which way round the "beveled" can chain tensioner gasket/washer goes on?
The washer has a bevel whereby the inner edge of the washer is at a different plane from thge outer edge. If you were to lay the washer on a flat surface with the outer edge in contact with the flat surface, the inner edge would be about 1/16" highter than the surface.
Does the washer go on to the tensioner with the inner edge against the tensioner head or with the outer edge against the tensioner head?
Thanks.
BH
Thanks.
BH
