2000 v8 explorer won't stay in 1 (low) when I shift to it
MinorDetail
PA
2001 Explorer
Hello all.!
I'm at a but if a loss right now being how I have never seen this issue. I put my truck in 1 (low gear) and start going but without even getting on the gas a lot my tranny shifts to 2nd? Usually, as you know, it will stay in first and the rpm's will keep going higher as I get to around 20 mph. But before the rpms even get to 3500 it shifts to 2nd ???? In 1st????? Someone explain please!
C 2000 Ford Explorer Sport Headlights constantly on and won't turn off Stock 1995 - 2001 Explorers 3
A 2000 Explorer Limited: liftgate handle won't open Stock 1995 - 2001 Explorers 0
S 2000 Explorer won't crank after motor is hot Stock 1995 - 2001 Explorers 8
P 2000 explorer xlt v6 auto won’t move Stock 1995 - 2001 Explorers 11
T 2000 Explorer 4.0 won't start Stock 1995 - 2001 Explorers 1
F 2000 Ford Explorer xls 4.0L won’t Start some times Stock 1995 - 2001 Explorers 5
M 2000 Explorer Won't start Stock 1995 - 2001 Explorers 4
D 2000 Explorer Eddie Bauer - won't start alarm- horn stays on Stock 1995 - 2001 Explorers 3
G 2000 Explorer won't fully shift into park... Stock 1995 - 2001 Explorers 1
B 2000 Explorer won't start Stock 1995 - 2001 Explorers 4
B 2000 explorer won't turn off Stock 1995 - 2001 Explorers 5
E 2000 Ford Explorer won't stop honking? Stock 1995 - 2001 Explorers 5
H 2000 Explorer won't crank or start sometimes after driving it for awhile and parking Stock 1995 - 2001 Explorers 9
M 2000 Ford Explorer V8 5.0L Won't Start Stock 1995 - 2001 Explorers 0
M 2000 Explorer limited 5.0 won't start Stock 1995 - 2001 Explorers 14
6 2000 Ford Explorer won't start Stock 1995 - 2001 Explorers 34
A 2000 Explorer won't start Stock 1995 - 2001 Explorers 4
B 2000 Explorer XLS won't go into gear Stock 1995 - 2001 Explorers 2
L 2000 Ford Explorer won't start Stock 1995 - 2001 Explorers 9
L 2000 Explorer won't start - Theft light *not* blinking Stock 1995 - 2001 Explorers 7
R My 2000 Explorer won't start. Stock 1995 - 2001 Explorers 3
M 2000 Explorer 4x4 Limited turns over but won't start. Stock 1995 - 2001 Explorers 6
W Need help; 2000 Explorer 4x4 v6 "brake" lamp on panel won't come on Stock 1995 - 2001 Explorers 15
C 2000 Explorer Won't Start Stock 1995 - 2001 Explorers 3
S 2000 explorer won't idle Stock 1995 - 2001 Explorers 3
L Keyless entry 2000 Ford explorer XLS Stock 1995 - 2001 Explorers 2
D Possible PCM damage, PCM and electrical function diag. 2000 Ford Explorer Limited Stock 1995 - 2001 Explorers 1
T 2000 Ford explorer transmission problems Stock 1995 - 2001 Explorers 2
C 2000 Explorer EB,Help needed no power to fog lights radio cutting in and out after replacing starter Stock 1995 - 2001 Explorers 0
J 2000 explorer no dash lights Stock 1995 - 2001 Explorers 1
R 2000 XLT and 2001 Explorer EB with broken seat tracks! Stock 1995 - 2001 Explorers 1
C 2000 Explorer Sport SOHC Overheating Stock 1995 - 2001 Explorers 8
P Preventative Maintenance 2000 Ford Explorer Stock 1995 - 2001 Explorers 10
C 2000 E.B. Explorer / Thermostat Sensor Part #'s Stock 1995 - 2001 Explorers 2
L Best v8 engine replacement for 2000 explorer Stock 1995 - 2001 Explorers 2
J 2000 explorer no taillights or dash lights Stock 1995 - 2001 Explorers 9
T 2000 Explorer wiper problem Stock 1995 - 2001 Explorers 9
K 2000 Ford Explorer High Idle Stock 1995 - 2001 Explorers 2
T Hi all hope your doing well... I recently acquired a 2000 explorer and im having a problem with 02. Stock 1995 - 2001 Explorers 7
fast_dave 2000 Explorer 2WD 5.0 For Sale - SF Bay Area Stock 1995 - 2001 Explorers 0
S 2000 Explorer Eddie Bauer edition Mach Audio upgrade Stock 1995 - 2001 Explorers 3
C 2000 Ford Explorer Sport Break Light Socket Replacement Stock 1995 - 2001 Explorers 2
C 2000 Ford Explorer Sport stumped on electrical problem Stock 1995 - 2001 Explorers 9
R Swap Vin E with Vin X on 2000 Ford Explorer? Stock 1995 - 2001 Explorers 8
A Will 5R55E from 2000 4.0 Mounty bolt into 1998 4.0 Explorer? Stock 1995 - 2001 Explorers 4
D 2000 Explorer dog guard Stock 1995 - 2001 Explorers 0
D 2000 Eddie Bauer Explorer Radio Stock 1995 - 2001 Explorers 5
B 2000 Explorer “clunks” going IN to park Stock 1995 - 2001 Explorers 1
P Beginning of a beautiful journey, 2000 Explorer SOHC Stock 1995 - 2001 Explorers 70
G Want to modify 2000 Explorer XLT 5.0 (53K miles) Stock 1995 - 2001 Explorers 31
Similar threads
