The hub is bolted to the outer side of the knuckle, and the cv axle end that goes into it only holds it into place afaik. The"stub" isn't pressed against anything, it doesn't even make contact with the knuckle. (Well, mine did.. which is why everything went to hell.. haha) I'm just not understanding how on our vehicles running without a cv axle, can damage the hub..
Because the way I see it, that axle nut, and the cv axle end that goes into the hub.. it's designed that way to (obviously, turn the front wheels) and to keep the cv axle in at a stable place without any in-out movement in the hub assembly. It's not really holding anything together.. I've taken a hub assembly and pulled it into two parts.. (yeah... that's how bad it got..) and the part that spins goes all the way to the inside part.. with a little bit of the case being back there too.. (prolly a good idea to grease or anti-seize this part up btw) I don't see how having that shaft in holds anything together, only holds the axle in-place.
