JeffD11N
- February 4, 2004
- PA
- '01 XLT
My x keeps kicking a cyl 2 misfire. Random misfire and lean bank 1 codes come up but after you clear them the cyl 2 comes back right away.
I have replaced the motorcraft wires with new motorcraft wires and a new motorcraft platinum plug for that cylinder. Still sets the code. Figured it has to be the coilpack. New motorcraft coil, same cylinder 2 miss.
After a good number of non repeatable words I thought for giggles lets put a timing light on it to see what it flashing. 7 cylinders flash the normal steady pulse. Number 2 on the other hand will flash a couple of times then give you a bursts of flashes between the normal pulse rate that may do it real quick or give a multiple 5 second long burst. There is no pattern at all to the bursts. The silly ******* is over firing and getting out of time.
Any ideas?
Any ideas?
