Steve,, can you give me info on the doughnut shaped rubbers that fit between chassis, and body on my 2001 sporttrac, (4WD) how easy to replace, cost of the ford part (aprox) ..........most of the rubbers under my truck are shot and perished, rotted away, and I wonder if a bumping sound could be body , chassis contact ?? looking under the truck there is 8 rubbers each side fitting under, and over the chassis mounts, the compound is rubbish, and crumbles to the touch, I have a guy here in CDO who has the metal mould to cast new rubbers of a much better and durable compound as replacements, as usual your thoughts are highly regarded..............Larry
