koda2000
- September 2, 2011
- x
About a month ago I notice a slight miss when climbing a steep hill near my house in high gear. I was waiting for it to throw a CEL but it never did. I had replaced my spark plugs about 20k ago with Autolite double platinum's so I didn't think that was the issue. The previous owner had his mechanic replace the plug wires (with Motorcraft brand wires) at some point in the not too distant past, so that didn't immediately jump out at me. Upon examination I noticed that the replacement plug wires were routed in the easiest way possible for the mechanic, rather than using the factory wire retainer clip locations and wire routing. I know this because I replaced the OE plug wires on my daughter's '00 5.0L Mountaineer last spring and the OE routing was a pain to duplicate. Plus opening the wire retainer clips without knowing their secrets is also a joy.
Today was sunny and 78 degrees in GA (gotta love that) so I decided I'd at least get one side rewired and install new plugs. I decided to begin with the driver's side, as those plugs take a beating with the wasted-spark. The plugs looked fine, but as I'd bought a set of Autolite double platinum's off RA (which included a $16 rebate) I decided to install new plugs and a new set of plug wires.
It was a pain trying to figure out which wire would work best with the OE routing because the PO's mechanic just put any wire that would reach where ever. I found I was missing 1 of the OE wire retainer clips for the driver's side, but the majority of them were there just not used where they belonged. I finally got the new wires routed to my satisfaction and took it for a test drive. No more miss. I'll wait until another nice day before I do the passenger side.
If any of you "junk yard dogs" (you know who you are) happen to see a Ford 5.0L with its original plastic wire clips on the driver's side valve cover (they snap onto a small post which is welded to the top of the VC and there are 2 used on the driver's VC) I need at lease one. These retainer clips have space for 3 wires, but are only used to hold 2. Note: You'll probably need to cut the plug wires as opening these clips with the wires in the vehicle is nearly impossible. These 2 clips need to be snapped off from the side, not pulled.
As I haven't attempted the passenger side wires yet so I don't know what I might be missing there. There are several different wire retainers used on this vehicle/engine...
- The 2 used on top of the driver's side VC used for cylinders 7 and 8.
- 2 that slides over posts on the two passenger side VC bolts. This clip holds just one wire and is used under the intake plenum and the rear of the VC for the #4 plug wire. They fit onto 2 special bolts used on the valve cover.
- Ones that holds 2 wires and the clip has a push-in style Xmass tree clip which fit into special brackets used on both sides of the front of the engine. These are used to hold the plug wires for cylinders 5 & 6 and cylinders 1 & 2.
- Basic clips that hold 4 wires, float and just snap closed (there are a few of those used near the coil pack on both sides)
- I think there's one 3-wire clip used on the passenger side and it holds the wires for cylinder 1, 2, and 3.
Without using the factory wire retainer clips (and routing the wires properly) you run the risk of burning a $90 wire set on the exhaust manifolds or from rubbing on various things under the hood.
