OneBadExpSport
- October 17, 2002
- Orange County, CA
- 2001 Explorer Sport
I need to upgrade my front lift which is currently lifted using the torsion bars which has caused me many problems. I'm thinking about upgrading to a spindle lift but am not sure which brand and type to use. Secondly I'm not even sure it will fix my problem.
A while back offroading, I ran into dirt mound which ended up being a boulder covered with a lot of dirt. This pushed my entire front end toward the back of the wheelwell. I barely made it home driving back only being able to turn the steering wheel 90 degrees in both directions.
I took it to a body shop to repair it and after the $500 repair, the front alignment was extremely off--about this bad. // \\ The tires wore out really quickly on the insides until I had a cam adjuster kit installed. However it is still pretty bad and my inside treads are all worn out.
My question is would a spindle lift kit in the front help to alleviate this problem? Or should i have it fixed up by a body shop? Thanks
