Echo11
- February 27, 2019
- 2001 ford explorer sport
HI, trying to help my nephew out here. He has had problems the last few months with fuel filters clogging. He first had this happen on the way home from work. He had the old ran out of gas symptom. The garage changed the filter that time as he was busy. Ran fine for weeks then did the same thing. He installed another new filter and it ran good another month. 3rd time he changed it out it only lasted a day till it gave the same symptoms. Runs a short while then sputters and shuts off.
I was wondering if these have a known problem with this happening. bad gas tanks or lines or something.
He also said he has an error that says o2 sensor. Why he plugged it in w/out a check engine light I am not sure but he did and found that o2 error. And the check engine light does work. It lights up when you have the key forward. But does not light while driving..
Any ideas what this may be would be appreciated..!!! thanks, jeff
