scott3204
- February 7, 2010
- carrollton Texas
- 2001 Explorer Sport
Help Please!! at least any insight, had been looking around at postings on this and im leaning that valve train is rattling some. Since sounds like a rattle at times rather that ticking, could this be a cam ordeal, and common problem with this motor?
Its the 4.0 with 134000 miled, had checked for any leaks, loose bolts etc, and just certain its on the inside valve area. I had changed the oil, added lucus, ( engine flushed a change before) and like all said in other post helped at bit at first, but rattles a bit later.
Truck still drives like a champ, good power, easy starting, no smoking, no rough anything.( cept kinda sounds like a soft diesel if that makes sense)
Is it cool to keep driving for now? Is this somewhat an easy fix to complete or do I Look for another engine?
Thanks for any thoughts...
