danthefordman
- December 5, 2010
- Saskatchewan
- 1999 XLT 4x4 & 2003 XLT
I have a 2001 Ford Explorer Sport and the low beam headlights will not go off period. I can remove the key, the headlight switch is off, and the low beams remain on. They will not shut off after an hour or more. The only way I have managed to shut them off is by removing the two fuses in the engine compartment box...one for the left low beam headlight and one for the right low beam headlight. So now I am using the fog lights as low beams, and the high beams work fine as normal.
I installed a new Hi/Low Beam/Signal Switch (Multifunction Switch), and no difference...low beam lights will remain on as before.
Can anyone help? Is it the GEM Module behind the radio?? Has anyone had this problem before? I can't seem to find any threads where people have had this exact problem.
