2001 Explorer Sport Transfer Case | Ford Explorer Forums - Serious Explorations
DevinG
2001 Explorer Sport SAS
Alright i out a dana 60 under the front of my explorer. I had the factory shaft shortened and the right yoke to the new axle. My problem now is the factory joint at the transfer case it looks almost like a cv joint but its not. The angle is too steep for that type of joint but would work fine with a u joint. Im not sure what transfer case it is maybe a borg-warner 1354? not sure where to look. What I'm asking is if there are any way to adapt that transfer case to a regular yoke for a u joint in the front.
Thanks
Devin
Devin I believe what you have is a BW4405, and if you take the front output shaft from an early model it might be what you are seeking. I'm just not sure when they changed to to cup flange.
Ok what years should i be looking for? and i will have to change out the whole output shaft correct?
