Allyreg
- December 1, 2021
- Fairhope, AL
- 02 Expl XLS 04 Expl XLT
Hey I’m ally. I’m new here! I was looking for wiring diagrams for my 2001 Explorer XLT. Mainly just the starting, transmission, and ignition diagrams would help! I seem to have a short somewhere on the ignition wire circuit. The ignition wire was burnt under the hood fuse box at the starter relay and blower motor relay and from the ignition switch fuse into the cab and into the fuse box under the dash and also burnt into the radio wiring harness. So I’ve lost power to most relays under the hood and most fuses under the dash. The battery constant wire in the radio harness doesn’t seem to be hot anymore. The transmission seems to be in limp mode. The battery dies very quickly so I have to unhook the negative cable every time I cut it off. Which is probably just a handful of the problems this SUV has. The best thing I can figure, which I’m no mechanic, is that some sort of straightwiring might have been done at the starter to ignition for the ignition wire to be as burnt as it is. If anybody has any thoughts on where I could begin thanks in advance. And if it’s too much of a headache, like it is for me, then wiring schematics would be a huge help!
