2001 Ford Explorer radiator hose help! | Ford Explorer - Ford Ranger Forums - Serious Explorations
ExplorerFord2001
lax
2001 explorer sport
Newbe, can't find links to help with installing a new radiator hose the upper & lower myself (non- experienced with mtc.) I went to Ford this morning and picked up the two hoses. There were no sleeves or clamps included.
What do I do next. Is this hard to change? Do I need tools?
Thank you for your assistance.
2001 ford explorer sport
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Welcome to this forum! I've moved your thread into the stock 95-01 section. It's a very easy job. Disconnect the 2 clamps on each hose, and remove the old hose. Tighten the clamp on the new hoses when you're finished.
renegadepig
spokane, wa
90 aerostar/98 explorer
since you are replacing them, use a utility knife to cut the old ones parallel to the outlets. saves trying to wrestle them off!
