Silverbullet1
- July 3, 2014
- Round Rock, Tx
- 2001 Ford Explorer S/T
Hoping this is where I can post my question...
I bought a cruise control switch from Ford (SW5928) due to deteriorated buttons on the left side, and the lights not working anymore on the right side. BUT the cruise control still worked fine.... When I was replacing the buttons, I had a heck of a time removing the old connections, from the deteriorated buttons, and low and behold they broke. So I ended up using the new harness....I also had a hard time removing the connections off the NEW buttons, to be able to thread the harness, but managed. I took the old harness off the right side first because I had to remove the horn bracket to be able to feed it through.. I managed that, connected it the same way the old one was. then went to the left, removed the old harness (to make sure I did everything just as the old working one was) Had everything connected beautifully. Put everything back together, hooked up the battery, and went to road test. Well, the Speed control light on the instrument cluster now flashes on it's own every few seconds while the engine is on! Drove it anyway, to check things out. The buttons push in but the cruise control does not work, and the light just flashes.... When the headlights are turned on, the left cruise on/off button is lit up, but the right one is not.... so I re-did everything again to make sure all connections on the button and the ground etc. was connected and all look fine. Can anybody tell me if the harness on the new one is a defective part???? I called Ford parts, but they never heard of that happening after replacing with a new, and want $110,00 just to diagnose! So I cam back here to find help. Has anyone ever had this trouble before, and what do I check??? Please help....
