2001 Ford Explorer Sport type of tranny
Oneadam12
Brandon, ms.
2001 Ford explorer sport
I have a 2001 Ford Explorer sport 4.0 2wd I'm trying to find out what type of transmission I have. The one I have now is smoked and I'm trying to see which one it is so I can find another
The code on door is D
TIA
koda2000
x
5R55_ Not sure of the last letter 5R55E are common, but I don't recall if the 2001 is an E. I'd look for one out of a 2001 to avoid possible electrical connector differences. If you take your VIN number and look at the vehicle details on Ford's ETIS site if will probably say to make sure.
G 2001 ford explorer trac 2001-2005 Explorer Sport Trac 2
D 2001 Ford Explorer SportTrac Coolant HeaterValve Replaced 2001-2005 Explorer Sport Trac 0
D 2001 Ford Explorer SportTrac OilPressurized Timing Tensioners Replaced 2001-2005 Explorer Sport Trac 11
D 99 Ford explorer sport trac and 2001 Ford explorer sport trac 2001-2005 Explorer Sport Trac 14
T 2001 Ford Explorer Sport Trac 6cyldr 4w dr 2001-2005 Explorer Sport Trac 1
H 2001 ford explorer sports trac tranfer case motor issues 2001-2005 Explorer Sport Trac 3
H 2001 ford explorer sports trac 2001-2005 Explorer Sport Trac 2
S 2001 Ford Explorer Sport Trac Tailgate won't open 2001-2005 Explorer Sport Trac 2
C 2001 Ford Explorer Sport Trac Looking to buy 2001-2005 Explorer Sport Trac 1
T 2001 Ford Explorer Sport Alarm System Help? 2001-2005 Explorer Sport Trac 1
H 2001 ford explorer sports trac 4x4 issue 2001-2005 Explorer Sport Trac 19
M Parts from a 2004 Ford Explorer that can be used in a 2001 Ford Sport Trac 2001-2005 Explorer Sport Trac 1
A 2001 ford explorer sport trac wont recognize computer 2001-2005 Explorer Sport Trac 0
S 2001 Ford Explorer Sport Trac Cruise Control Buttons 2001-2005 Explorer Sport Trac 8
R 2001 Ford Explorer Sport Trac 2001-2005 Explorer Sport Trac 16
N 2001 Ford Explorer Sport Trac Back Window Problem 2001-2005 Explorer Sport Trac 1
B 2001 Ford Explorer Sport Trac won't start! 2001-2005 Explorer Sport Trac 5
M 2001 ford explorer sport trac starting problems 2001-2005 Explorer Sport Trac 4
G How to add Transmission Fluid on a 2001 Ford Explorer Sport 2001-2005 Explorer Sport Trac 2
D Lost Key for 2001 Ford Explorer 2001-2005 Explorer Sport Trac 1
L Wanted Need Parts! 2001 Ford explorer sport trac. 2001-2005 Explorer Sport Trac 6
M 2001 Ford Explorer with an oil pan gasket leak. 2001-2005 Explorer Sport Trac 1
J 2001 Ford Explorer Sport Trac with a couple of issues. 2001-2005 Explorer Sport Trac 2
R 2001 ford Explorer sport trac won't start 2001-2005 Explorer Sport Trac 6
A 2001 Ford Explorer Sport Trac 2001-2005 Explorer Sport Trac 8
M 2001 Ford Sport Trac Intermittant 2001-2005 Explorer Sport Trac 8
C 2001 Ford Sport Trac anti theft light keeps blinking car won't start 2001-2005 Explorer Sport Trac 1
D lift kit help 2001 ford sport trac 2001-2005 Explorer Sport Trac 23
B Rebuilding a 2001 Ford Sport trac Need Help 2001-2005 Explorer Sport Trac 3
W 2001 Ford Sport Trac Seat Belt 2001-2005 Explorer Sport Trac 1
F 2001 ford sport 2001-2005 Explorer Sport Trac 0
N 2001 Ford Sport Trac Bench Seat 2001-2005 Explorer Sport Trac 7
B How to remove spare tire on 2001 ford sport trac 2001-2005 Explorer Sport Trac 6
M 2001 Ford SOHC 4.0L Going out. Recalled? 2001-2005 Explorer Sport Trac 3
K 2001 Ford Sport Trac - Replace seat belts for back seat? 2001-2005 Explorer Sport Trac 1
S 3" body lift 2001 ST 2WD Manual 2001-2005 Explorer Sport Trac 5
N2FORD 2001 Fuel pump bad, newer tank? Fixed 2001-2005 Explorer Sport Trac 14
C 2001 Explorer Sport - Rear End Vibration 2001-2005 Explorer Sport Trac 2
G 2001 Sport trac interior driver side floor is soaked 2001-2005 Explorer Sport Trac 2
D ISO used 2001 sport trac hard topper 2001-2005 Explorer Sport Trac 2
B 2001 sport trac drivers seat 2001-2005 Explorer Sport Trac 4
S Hello, Back again, need help with 2001 sport trac Trans problem 2001-2005 Explorer Sport Trac 6
K 2001 Engine Bay 2001-2005 Explorer Sport Trac 1
A 2001 explorer sport trac 2001-2005 Explorer Sport Trac 3
R 2001 Sport Trac trans issue 2001-2005 Explorer Sport Trac 0
mafloc78 2001 Sport trac brake light switch 2001-2005 Explorer Sport Trac 0
D 2001 explorer sport trac 4x4 system 2001-2005 Explorer Sport Trac 3
W Use 2002 EBauer body parts for 2001 Sport Trac 4x4 2001-2005 Explorer Sport Trac 2
M 2001 Explorer Sport Trac Coolant Issue 2001-2005 Explorer Sport Trac 4
T 2001 Sport Trac Dog Box 2001-2005 Explorer Sport Trac 0
Similar threads
