For Sale 2001 Ford Sport Trac
thunderhorse
Elite Explorer <br><img src="/forums/images/icons/
Nashville Tennessee
2001 Sport Trac 4x4
SOLD 2001 Ford Sport Trac
SOLD
Found title re-posted
2001 Ford Sport Trac 4X4 Auto, $4500
230K miles
THE GOOD STUFF
ENGINE
4.0LITER V6
TOP END REBUILT IN '07 WITH NEW HEADS, NEW REAR TIMING CHAIN, AND ALL APPLICABLE GASKETS.
NEW RADIATOR 07
K&N FIPK FUEL INJECTION PERFORMANCE KIT
PROFORD MASS AIRFLOW SENSOR 07
NEW WATER PUMP 09
NEW PLUGS AND WIRES. 10.
A/C COMPRESSOR REPLACED 10
DRIVE TRAIN
5-SPEED AUTOMATIC TRANSMISSION WITH OVERDRIVE REPLACED WITH A FACTORY REBUILD 06
FLUID CHANGED NOV 10
SHIFT-ON-THE-FLY 4WD TRANSFER CASE REPLACED 09
4.56 RATIO GEARING (FRONT AND REAR, INSTALLED IN 05
FRONT PINON SEAL REPLACED 09
RIGHT FRONT HAFT-SHAFT REPLACED 09
SUSPENTION
SUPERLIFT 4” LIFT 05
SUPERLIFT FRONT DRIVE SHAFT (INSTALLED IN '05
SUPERLIFT 4” REAR LEAF SPRINGS 05
WARRIOR 2" SHACKLE S 05
RIGHT FRONT BALL JOINT REPLACED 09
RESENT FRONT ALIGNMENT
33 12.5 /15” BGF KO AT TIRES, 15/10 ALUM WHEELS RIMS
EXHAUST
REPLACED THE PRECAT AND MAIN CAT SYSTEMS WITH NEW OEM PARTS FROM FORD
ADDED A CAT- BACK SYSTEM INCLUDING A 2.5" MID-PIPE, A 40 SERIES DELTA FLOW 2 CHAMBER FLOWMASTER MUFFLER
AND A 3" PIPE OUT THE BACK WITH A 12" DOUBLE-INSULATED WICKED FLOW TIP INSTALLED IN '05
BODY
3”BODY LIFT
ORIGINAL BLACK PAINT FROM THE
AUTOMATIC SUN ROOF
AUTOMATIC SLIDING REAR WINDOW WITH SAFETY SENSOR
2-SIDED LOCKING TONNEAU COVER AND 2FT BED EXTENDER
12V/20AMP POWER POINT IN THE BED
CLASS 3 HITCH
ALSO HAVE A TOW BAR IF WANTED
INTERIOR
STOCK.LIGHT GREY CARPETING WITH CHARCOAL GREY LEATHER UPHOLSTERY
DRIVER'S SEAT REUPHOLSTERED 10
LED DOME LIGHTS 10
NOW THE BAD
TRUCK NEEDS SHOCKS
OIL PRESSURE SENDING UNIT
SUN ROOF LEAKS
HAS A VIBRATION IN THE SEATS OVER 60MPH (MAY NEED A U-JOINT/TIRE BALANCE)
ABS MAY NOT BE WORKING (LIGHT IS OUT)
PAINT HAS SOME SCUFFS HERE AND THERE
ONLY DENTS SMALL AT PASSENGER’S DOOR AND TAIL GATE
E-Mail Tthunderhorse6@netscape.net remove first T
thunderhorse
Nashville Tennessee
2001 Sport Trac 4x4
bump
thunderhorse
Nashville Tennessee
2001 Sport Trac 4x4
oops sorry $4500
wantedexplorer
Jay, Maine
96 Eddie Bauer V8
What about mileage? Does it come with the winch?
exploader98
Sparta, Nj
'98 XLT
would u be lookin for cash or would u do a trade?
thunderhorse
Nashville Tennessee
2001 Sport Trac 4x4
The will be removed. Would trade for an early Ford diesel.
