2001 Sport: Rear blinkers/brake lights don't work. Everything else does.
steventadams
New Jersey
2001 Sport
Okay so I'm in a bit of a pickle.
A few weeks ago my Compass/Dome light went out. My right rear blinker then went out. Then my left rear blinker went out. They all share a common ground according to my Haynes Manual. The front blinkers and indicators on the dash work fine. I did continuity checks on the MFS and it's still good and the rest of the MFS works fine.
The fuses all lit up my test light except a few that didn't light up on either side so I assume those are spares. Does anyone have a fuse box diagram or list? Haynes doesn't have one.
I don't have power to either rear blinker so I've ruled out a bad ground. The Haynes Manual shows the blinkers share a pigtail somewhere upstream of the lights but I have no idea where it is.
Does anyone have any sort of map or wiring diagram that shows physically where junctions and wiring harnesses are in this dang vehicle? I need to get these things working.
Any ideas? Thanks.
Edit: I also did continuity checks on the bulb sockets, they are good. The bulbs themselves are new as well. The high mount brake light works fine also. It's just those two bulbs that don't have power.
swshawaii
Kailua-Oahu, Hawaii
'05 Sport Trac XLS (RWD)
Just to be safe, assume this means from the "B" pillar forward. There are differences with the 2001 ST Job 1 and Job 2 engines.
The 01-03 Sport has EXACTLY the same front end as the 2001-2005 Sport Trac .....NO difference. They are totally different from the regular 4-door Explorer.
http://www.explorerforum.com/forums/showpost.php?p=2622504&postcount=9
Fuse diagram shown in the owners manual.
https://owner.ford.com/servlet/Cont...oLogin=Owner/Page/OwnerGuidePage&ord=31290510
Repair Manuals & Wiring Diagrams
http://www.explorerforum.com/forums/showpost.php?p=3302084&postcount=4
TSB's & Wiring Diagrams
http://www.bbbind.com/free_tsb.html
cwol97401
Duck Country Oregon
1997 Merc Mounty 5.0L
This is worth a mention just because I had the same problem om my ford escort:
Note:my escort was a 97 so it may not be the same issue but it is possible.
I am also assuming you have a trailer wiring harness.
After I added a trailer harness to my factory wiring i put too big of a load on my flasher unit under the dash and burnt out the contacts for the rear lights. On mine, there was a flasher box that was twice the size of a relay and had about 10 wires going to and from it (each corner of the car is controlled independently). the flasher box has circuits for each bulb in it and if one burns up it quits working. my flasher was a yellow box fastened way up under the dash.
A second problem area could be the grey connector for the hazard flasher switch, the brake and turn wires run through this plug and switch. on my mountaineer, the switch became brittle and the wires broke free. I replaced the big grey plastic connector and everything worked great again. There are two harness connectors, my issue was with the upper one next to the flasher switch, not the lower one next to the indicator lever.
happy endeavors.
steventadams
New Jersey
2001 Sport
happy endeavors.
My wiring diagrams don't show a blinker relay unfortunately and the hazard switch looks to be upstream of the blinker wiring. I never did verify that my front hazards were working. The indication lights up on the dash with the hazards though.
swshawaii
Kailua-Oahu, Hawaii
MAS Tequila
Boca Raton FL
2000 Mounty 4WD 5.0
A buddy of mine had the same symptoms with an '03 Sport.
It ended up being the MFS.
MT
steventadams
New Jersey
2001 Sport
MT
Maybe I'd be better off just changing it out just to verify. I don't see how it could be the problem though if the other signals light up.
According to the Haynes Manual there is a common blinker output from the MFS that splits into 3 leads, 1 for rear 1 for front 1 for dash. 2 of those 3 light up correctly but the one doesn't.
steventadams
New Jersey
2001 Sport
Just for the heck of it, try tilting the steering column all the way UP. If that helps you have a MFS connector issue. 2001-03 two door Sports are identical to 2001-05 Sport Tracs from the "B" pillar forward. There are differences with 2001 ST Job 1 & 2 engines.
http://www.mysporttrac.com/MySportTrac/projects/Steering_Column_Wiring_Repair_Gen1.pdf
I tried tilting all the way but no luck. The connectors are definitely loose. But the problem persists even when I manually hold them in place.
I've also verified with a test light that I get power to the MFS output wire for each blinker.
steventadams
New Jersey
2001 Sport
Shit. The wiring diagram for the 2001 Sport Track is different from the one in my Haynes Manual. I may have been working off the wrong diagram. This may solve many problems for me.
swshawaii
Kailua-Oahu, Hawaii
Thanks Hayne's..... again. :fire:
cwol97401
Duck Country Oregon
V 2001 Explorer Sport Rear Hatch Question Stock 1995 - 2001 Explorers 1
V 2001 Sport Rear Glass support pins Stock 1995 - 2001 Explorers 0
B Rear sway bars for 2001 Explorer Sport 2-door Stock 1995 - 2001 Explorers 3
D 2001 Ford Explorer Sport Rear Window Does not Latch Stock 1995 - 2001 Explorers 2
H 2001 Explorer Sport...Loud bang from the rear end? Shocks? Struts? Stock 1995 - 2001 Explorers 12
L 2001 Sport Rear Hatch Glass Handle Stock 1995 - 2001 Explorers 4
G 2001 Explorer Sport whining/whirring noise in rear end Stock 1995 - 2001 Explorers 0
M Transfer case/rear end slop question 2001 sport 4x4 Stock 1995 - 2001 Explorers 0
N Rear Swing arm problem...need help - Ford Explorer Sport 2001 Stock 1995 - 2001 Explorers 7
H 2001 Sport Rear Wheel Vibration Stock 1995 - 2001 Explorers 7
R 2001 sport rear axle replacement Stock 1995 - 2001 Explorers 1
V Tire replacement on 2001 Sport with 4x4 Stock 1995 - 2001 Explorers 8
T 09/2001 Explorer Sport- 2 Door Manual Stock 1995 - 2001 Explorers 8
E 2001 ford explorer sport Stock 1995 - 2001 Explorers 2
B 2001 Explorer Sport - Door Lock lights stay on Stock 1995 - 2001 Explorers 9
J Rust damage to frame 2001 Explorer Sport 103,000 miles Stock 1995 - 2001 Explorers 9
L Upper control arm replacement part 2001 Explorer Sport Stock 1995 - 2001 Explorers 7
B 2001 Ford Explorer Sport. New MEMBER. HELP PLEASE! Stock 1995 - 2001 Explorers 10
E 2001 explorer sport clogging fuel filters Stock 1995 - 2001 Explorers 12
C Baffled by Heater Issue...2001 Explorer Sport Stock 1995 - 2001 Explorers 17
R 2001 Sport front end growl.... Stock 1995 - 2001 Explorers 8
A 2001 Explorer Sport stalling and not starting HELP Stock 1995 - 2001 Explorers 3
J 2001 Explorer Sport Won't turn over. Stock 1995 - 2001 Explorers 4
C Body mounts - 2001 Explorer Sport 2D? (NOT sport trac) Stock 1995 - 2001 Explorers 3
A Jack Extension bar 2001 Explorer Sport Stock 1995 - 2001 Explorers 5
A Help with finding a hood release cable replacement 2001 Explorer Sport Stock 1995 - 2001 Explorers 2
C 2001 explorer sport...doors detent/stay worn out Stock 1995 - 2001 Explorers 1
J 2001 ford explorer sport RWD engine swap help Stock 1995 - 2001 Explorers 4
N 2001 Ford Explorer Sport SUV differential or axle problems? Stock 1995 - 2001 Explorers 12
J Rack and pinion on a 2001 Ford Explorer sport Stock 1995 - 2001 Explorers 0
S 2001 Explorer Sport a/c mode problem Stock 1995 - 2001 Explorers 16
G Back glass strut, 2001 explorer sport Stock 1995 - 2001 Explorers 2
J Location of starter solenoid on 2001 explorer sport Stock 1995 - 2001 Explorers 2
J Location of starter selenoid on 2001 explorer sport Stock 1995 - 2001 Explorers 16
V 2001 Explorer Sport - passenger upper control arm 2pc Stock 1995 - 2001 Explorers 6
H 2001 4.0 SOHC 4x4 Sport Multiple Codes Stock 1995 - 2001 Explorers 1
R 2001 explorer sport 4.0L - automatic trans, will not start Stock 1995 - 2001 Explorers 1
J Yamaha 125cc fit in 2001 sport explorer Stock 1995 - 2001 Explorers 5
G Correct Radiator Size for 2001 Explorer Sport 4.0? 1" or 2"? Stock 1995 - 2001 Explorers 8
J 2001 Ford Explorer Sport (2dr model) Stock 1995 - 2001 Explorers 17
L PCV valve replacement for 2001 explorer sport Stock 1995 - 2001 Explorers 4
E 2001 Expo Sport 2dr Tailgate Replacement Stock 1995 - 2001 Explorers 4
C 2001 explorer sport pats issue Stock 1995 - 2001 Explorers 1
D 2001 Explorer Sport trouble.... Stock 1995 - 2001 Explorers 19
R 2001 Ford Sport Body Mount Bushings Stock 1995 - 2001 Explorers 3
B Replacing Timing Chains, Guides, Tensioners on FORD 2001 EXPLORER SPORT Stock 1995 - 2001 Explorers 10
T 2001 Explorer Sport (not sport trac) Stock 1995 - 2001 Explorers 4
E Seat issues... 2001 Expo Sport 2DR Stock 1995 - 2001 Explorers 1
J 2001 Sport Oil leak Stock 1995 - 2001 Explorers 1
S 2001 Ford Explorer Sport, lift gate repair Stock 1995 - 2001 Explorers 1
Similar threads
