mitch1204
- September 23, 2015
- Dayton, TN
- 1997 Ford Explorer XLT
Just go with a stock TC. Why bypass the tranny cooler in the radiator? Just add the external cooler to it and you have two. Sounds like you have loss of fluid pressure due to old gaskets and seals or you are getting torque converter slip which will heat your fluid up hot. 5r55e are about the easiest to rebuild. Good tough transmission. I seen a bunch the OD planet and sprag tear up so don't be surprised if they need replaced. If the kit didn't have it get a bushing kit. You'll need the one for the pump. It has one speed sensor inside, replace it while they are in there. Its your only chance. If it's in the shop they'll take care of you.
