2001 Sport Trac high beam indicator on. No headlights. | Ford Explorer - Ford Ranger Forums - Serious Explorations
bozzcrezo38
orlando, fl
2001 sport trac
Have a 2001 sport trac. When I turn the headlight switch on, the high beam indicator lights up but I have no headlights at all. Pulling high beam lever does nothing. All fuses are good, repalced the headlight bulbs and I DO NOT have daytime running lights. This is an intermittent problem. Having to drive with fog lights, just waiting to catch a kojacks eye. Any suggestions?
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
QuentinPittman
Brampton, ON
2002 Sprot Trac
02 Sport Trac High Beams
Have same problem, Turned lights on to go to work when High Beam Lit up and got a really strong smell of buring wires. The high beams wouldn't turn off even with light switch off. I removed the fuse for the high beams. The smell continued but went away after a little while. Hoping someone can offer some help.
MR YAT
Central NJ
2001 Explorer Sport trac
Quick question, have you tried raising the tilt wheel to the upmost position? do your directionals work?
