2001 Sport trac interior driver side floor is soaked
GenerationsofFord
Richmond
2001 Ford Sport Trac
I have a 2001 sport trac and went to clean it out today to find my driver side floor is soaked i checked the passenger and rear and its only in the driver side i checked the cowls with a garden hose and they are clear.. the water does smell like condensation water but it also rained this morning so its hard to say.. it could be my windshield as well considering its the stock windshield.. i would like to narrow it down by checking the ac drain if someone could point me in the right direction were it would be.. it would be greatly appreciated
1996xlt
South Mills, NC
95 F150 XLT 2WD
I'm pretty sure the A/C drain is outside of the cab; have you checked the sunroof drain lines?
This thread should help (for an older model X but still applies: leaking sunroof
koda2000
x
The A/C drain is on the passenger side, not the driver's side. It can become clogged, but that would get the passenger side floor wet. Do you have a sunroof? Our '00 Mountaineer had a wicked water leak on the driver's side that kept the driver's side floor sopping wet one Winter. I couldn't find where the water was getting in. This past Summer I noticed that there was a pretty big gap on the plastic around the windshield at the roof channel/grove. I filled in the gap with silicon, not expecting much, but ii's rained A LOT here all Winter and the floor has remained completely dry... IDK not a pretty repair, but it seems to have worked.
The sunroof. if you have one, has 4 drains (2 in the "A" pillars and 2 in the "B" pillars) that can become clogged and can even pull off the plastic tray they attach too.
D ISO used 2001 sport trac hard topper 2001-2005 Explorer Sport Trac 2
B 2001 sport trac drivers seat 2001-2005 Explorer Sport Trac 4
S Hello, Back again, need help with 2001 sport trac Trans problem 2001-2005 Explorer Sport Trac 6
M 2001 Ford Sport Trac Intermittant 2001-2005 Explorer Sport Trac 8
D 99 Ford explorer sport trac and 2001 Ford explorer sport trac 2001-2005 Explorer Sport Trac 14
T 2001 Ford Explorer Sport Trac 6cyldr 4w dr 2001-2005 Explorer Sport Trac 1
A 2001 explorer sport trac 2001-2005 Explorer Sport Trac 3
R 2001 Sport Trac trans issue 2001-2005 Explorer Sport Trac 0
mafloc78 2001 Sport trac brake light switch 2001-2005 Explorer Sport Trac 0
D 2001 explorer sport trac 4x4 system 2001-2005 Explorer Sport Trac 3
W Use 2002 EBauer body parts for 2001 Sport Trac 4x4 2001-2005 Explorer Sport Trac 2
M 2001 Explorer Sport Trac Coolant Issue 2001-2005 Explorer Sport Trac 4
T 2001 Sport Trac Dog Box 2001-2005 Explorer Sport Trac 0
M 2001 Explorer Sport Trac Making Noise 2001-2005 Explorer Sport Trac 3
K 2001 Sport Trac Transmission 2001-2005 Explorer Sport Trac 3
R 2001 Sport Trac No Power Steering 2001-2005 Explorer Sport Trac 1
bt93 2001 Sport Trac with no drive but has 1, 2 and r 2001-2005 Explorer Sport Trac 4
J 2001 Sport Trac Body Mount Bushings w/ Hardware 2001-2005 Explorer Sport Trac 32
mafloc78 Sport trac 2001 motor changed 2001-2005 Explorer Sport Trac 1
J 2001 Sport Trac tail lights & dash backlight not working, no bad fuses 2001-2005 Explorer Sport Trac 3
G 2001 Sport Trac 2001-2005 Explorer Sport Trac 1
P 2001 Explorer Sport Trac PATS system. 2001-2005 Explorer Sport Trac 9
S 2001 Ford Explorer Sport Trac Tailgate won't open 2001-2005 Explorer Sport Trac 2
S 2001 Explorer Sport Trac Window Help 2001-2005 Explorer Sport Trac 10
A Interchangable parts for 2001 sport trac 2001-2005 Explorer Sport Trac 3
K 2001 sport trac starts dies, then dosen't start 2001-2005 Explorer Sport Trac 15
C 2001 Sport Trac Cummins Conversion 2001-2005 Explorer Sport Trac 3
Paul Fithian New to Me 2001 Sport Trac RWD Automatic 2001-2005 Explorer Sport Trac 28
C 2001 Ford Sport Trac anti theft light keeps blinking car won't start 2001-2005 Explorer Sport Trac 1
S 2001 Sport Trac wiring diagrams 2001-2005 Explorer Sport Trac 2
H 2001 & Early 2002 Sport Trac Fuel Hardline Compared To Late 2002 / 2003 2001-2005 Explorer Sport Trac 1
S 2001 Sport Trac 2001-2005 Explorer Sport Trac 6
C 2001 Ford Explorer Sport Trac Looking to buy 2001-2005 Explorer Sport Trac 1
B 2001 Explorer Sport trac engine shut off 2001-2005 Explorer Sport Trac 3
W 2001 sport trac leaking roof 2001-2005 Explorer Sport Trac 3
W New Owner Introduction 2001 Sport Trac 160k miles 2001-2005 Explorer Sport Trac 4
E 2001 Sport Trac ... Engine "Problem" & Replacement 2001-2005 Explorer Sport Trac 8
J 2001 Sport trac bad chain chain guides...Suprise lol 2001-2005 Explorer Sport Trac 8
mafloc78 sport trac 2001 wont start 2001-2005 Explorer Sport Trac 4
C 2001 sport trac tranny rebuild 2001-2005 Explorer Sport Trac 1
W 2001 Sport Trac Project 2001-2005 Explorer Sport Trac 24
L 2001 sport trac toolbox 2001-2005 Explorer Sport Trac 2
W My 2001 Sport Trac Project 2001-2005 Explorer Sport Trac 2
V 2001 sport trac anti theft ON 2001-2005 Explorer Sport Trac 0
T 2001 Sport Trac will not move 2001-2005 Explorer Sport Trac 0
F 2001 Sport Trac wont start. 2001-2005 Explorer Sport Trac 3
R 2001 sport trac squeaking noise - diagnostic assistance appreciated! 2001-2005 Explorer Sport Trac 2
A 2001 Explorer Sport Trac r&r left exterior door handle 2001-2005 Explorer Sport Trac 1
D Need advice - considering buying 2001 Sport Trac 2001-2005 Explorer Sport Trac 4
K Instrument cluster bulb replacement 2001 Sport Trac 2001-2005 Explorer Sport Trac 4
Similar threads
