2001 Sport Trac LOM location | Ford Explorer - Ford Ranger Forums - Serious Explorations
duhibrokeit
Alaska
2001 Sport trac
I have no headlights, but driving lights work. From reading the threads the LOM is the culprit. Can't look for the bad solder joint, or jumper it if I can't find it.
I have no center console, pulled the small tray at the center of the doghouse, and there is only the Restraints Control Modular.
No high/low beams. No power to inside fuse panel. My headlights are good besides drivers side low beam bad from testing the bulbs.
Thanks
ncranchero
Co-moderator
Moderator Emeritus
Denver,NC
1997 F150 XLT 4x4
LOM? Lighting module? Not one.
Check:
Battery junction box (BJB) fuse 24 (25A).
Headlamp switch.
Circuitry.
Multifunction switch.
duhibrokeit
Alaska
2001 Sport trac
So, i cleaned the switch, have some pits no help. No power in. I was looking at the Low beam fuses... which had some in there, but no connector in the back! :mad: Anyways, now that I looked through every fuse in the panel, they had a 7.5 amp fuse in the headlamp, now I know, #24... ugh... what happened to just putting a legend in the fuse panel? More money for ford because you don't want to look in your owners manual? One which I just downloaded. Okay soooooo that problem fixed, now dejamming the cd deck, and what ever else small might rear its head.
Thanks for the replay. I kept working my way backwards... wondered by the interior panel fuse had no power, but with out the diagram, didn't know if it ran though the switch or mfs either, so now I know.
Have a great day.
bobflood
Powder Springs, GA
1997 Eddie Bauer V8 2WD
Have a great day.
Great source for info - especially wiring diagrams:
Auto - Online Repair Info
http://search.ebscohost.com/
PW: rebsco
Follow prompts down to Wiring Diagrams.
duhibrokeit
Alaska
2001 Sport trac
Thank you so much for that info. This vehicle is in Nome, and just loaded with road dirt. I have pressure washed under it as much as possible, but still not good for the "sealed" electrical connectors having dirt in them too. No corrosion though.
