kaluahili
- April 7, 2017
- Location
- Waiau
- Hawaii
- '01 ST 4X4 V6 SOHC JOB 1
I have been having issues with my 2001 sport trac 4x4 v6 sohc fuel inj. 132k mileage. The problem is I can jump in and it will start first try, fuel pump is heard activating, idle is rough, feels like truck is about to die, pumping on the gas usually causes it to catch and smooth out......after 10 mins. or sometimes less than that truck starts to sputter, step on throttle it dies faster, sometimes when stepping on throttle before it dies helps and truck is able to rev up and then back to idle and not die. But most times stepping on gas when it begins to sputter after running for 10 mins or so causes it to die once it dies it doesn't start back up and when key is turned on and off, no fuel pump activation noise.
I have scantool data take off a autel 619 saved to notebook text format. But have no idea how to post it here or if it is allowed. Any help is greatly appreciated, have a blessed day.
---------------------52 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 37.6 %
ECT 183 °F
SHRTFT1 13.3 %
LONGFT1 25.0 %
SHRTFT2 18.8 %
LONGFT2 25.0 %
RPM 651 rpm
VSS 0 mph
SPARKADV 18.0 °
IAT 84 °F
MAF 0.01 lb/s
TP 18.8 %
O2SLOC B1S12--B2S1---
O2B1S1 0.675 V
SHRTFTB1S1 14.1 %
O2B1S2 0.570 V
SHRTFTB1S2 99.2 %
O2B2S1 0.725 V
SHRTFTB2S1 17.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------53 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 183 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 14.8 %
LONGFT2 25.0 %
RPM 639 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 84 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.245 V
SHRTFTB1S1 12.5 %
O2B1S2 0.665 V
SHRTFTB1S2 99.2 %
O2B2S1 0.670 V
SHRTFTB2S1 14.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------54 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.8 %
ECT 183 °F
SHRTFT1 15.6 %
LONGFT1 25.0 %
SHRTFT2 22.7 %
LONGFT2 25.0 %
RPM 674 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.055 V
SHRTFTB1S1 21.9 %
O2B1S2 0.125 V
SHRTFTB1S2 99.2 %
O2B2S1 0.075 V
SHRTFTB2S1 29.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------55 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 183 °F
SHRTFT1 30.5 %
LONGFT1 25.0 %
SHRTFT2 36.7 %
LONGFT2 25.0 %
RPM 612 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.045 V
SHRTFTB1S1 35.9 %
O2B1S2 0.100 V
SHRTFTB1S2 99.2 %
O2B2S1 0.050 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------56 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.4 %
ECT 183 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 720 rpm
VSS 0 mph
SPARKADV 15.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.770 V
SHRTFTB1S1 35.9 %
O2B1S2 0.090 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------57 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.6 %
ECT 181 °F
SHRTFT1 27.3 %
LONGFT1 25.0 %
SHRTFT2 27.3 %
LONGFT2 25.0 %
RPM 962 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 88 °F
MAF 0.02 lb/s
TP 22.4 %
O2B1S1 0.770 V
SHRTFTB1S1 17.2 %
O2B1S2 0.135 V
SHRTFTB1S2 99.2 %
O2B2S1 0.500 V
SHRTFTB2S1 16.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------58 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 45.9 %
ECT 181 °F
SHRTFT1 18.8 %
LONGFT1 24.2 %
SHRTFT2 12.5 %
LONGFT2 24.2 %
RPM 1666 rpm
VSS 0 mph
SPARKADV 21.5 °
IAT 88 °F
MAF 0.02 lb/s
TP 23.1 %
O2B1S1 0.745 V
SHRTFTB1S1 6.3 %
O2B1S2 0.375 V
SHRTFTB1S2 99.2 %
O2B2S1 0.080 V
SHRTFTB2S1 14.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------59 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 43.9 %
ECT 180 °F
SHRTFT1 3.1 %
LONGFT1 24.2 %
SHRTFT2 11.7 %
LONGFT2 23.4 %
RPM 1848 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 88 °F
MAF 0.03 lb/s
TP 25.9 %
O2B1S1 0.080 V
SHRTFTB1S1 9.4 %
O2B1S2 0.735 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 3.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------60 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 34.5 %
ECT 180 °F
SHRTFT1 0.0 %
LONGFT1 23.4 %
SHRTFT2 -0.8 %
LONGFT2 22.7 %
RPM 2454 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 90 °F
MAF 0.03 lb/s
TP 25.1 %
O2B1S1 0.060 V
SHRTFTB1S1 -0.8 %
O2B1S2 0.705 V
SHRTFTB1S2 99.2 %
O2B2S1 0.610 V
SHRTFTB2S1 0.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------61 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 27.5 %
ECT 181 °F
SHRTFT1 7.8 %
LONGFT1 25.0 %
SHRTFT2 8.6 %
LONGFT2 25.0 %
RPM 753 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.025 V
SHRTFTB1S1 24.2 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.040 V
SHRTFTB2S1 30.5 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------62 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 181 °F
SHRTFT1 28.1 %
LONGFT1 25.0 %
SHRTFT2 34.4 %
LONGFT2 25.0 %
RPM 581 rpm
VSS 0 mph
SPARKADV 19.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.040 V
SHRTFTB1S1 35.2 %
O2B1S2 0.080 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------63 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.2 %
ECT 183 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 707 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.075 V
SHRTFTB1S1 42.2 %
O2B1S2 0.055 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------64 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 37.3 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 531 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.020 V
SHRTFTB1S1 42.2 %
O2B1S2 0.040 V
SHRTFTB1S2 99.2 %
O2B2S1 0.015 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------65 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.5 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 685 rpm
VSS 0 mph
SPARKADV 16.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.365 V
SHRTFTB1S1 39.1 %
O2B1S2 0.045 V
SHRTFTB1S2 99.2 %
O2B2S1 0.600 V
SHRTFTB2S1 39.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------66 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.0 %
ECT 185 °F
SHRTFT1 39.1 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 620 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.040 V
SHRTFTB1S1 42.2 %
O2B1S2 0.045 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------67 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 718 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.750 V
SHRTFTB1S1 32.0 %
O2B1S2 0.080 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 34.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------68 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.8 %
ECT 185 °F
SHRTFT1 28.1 %
LONGFT1 25.0 %
SHRTFT2 32.8 %
LONGFT2 25.0 %
RPM 634 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.055 V
SHRTFTB1S1 29.7 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.785 V
SHRTFTB2S1 33.6 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------69 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.3 %
ECT 183 °F
SHRTFT1 21.9 %
LONGFT1 25.0 %
SHRTFT2 30.5 %
LONGFT2 25.0 %
RPM 656 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.040 V
SHRTFTB1S1 26.6 %
O2B1S2 0.130 V
SHRTFTB1S2 99.2 %
O2B2S1 0.040 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------70 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.0 %
ECT 185 °F
SHRTFT1 26.6 %
LONGFT1 25.0 %
SHRTFT2 30.5 %
LONGFT2 25.0 %
RPM 672 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.805 V
SHRTFTB1S1 20.3 %
O2B1S2 0.130 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 22.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------71 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.0 %
ECT 183 °F
SHRTFT1 14.1 %
LONGFT1 25.0 %
SHRTFT2 21.1 %
LONGFT2 25.0 %
RPM 694 rpm
VSS 0 mph
SPARKADV 18.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.065 V
SHRTFTB1S1 19.5 %
O2B1S2 0.600 V
SHRTFTB1S2 99.2 %
O2B2S1 0.660 V
SHRTFTB2S1 25.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------72 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.1 %
ECT 183 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 747 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 93 °F
MAF 0.08 lb/s
TP 30.2 %
O2B1S1 0.060 V
SHRTFTB1S1 42.2 %
O2B1S2 0.180 V
SHRTFTB1S2 99.2 %
O2B2S1 0.050 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------73 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 183 °F
SHRTFT1 23.4 %
LONGFT1 25.0 %
SHRTFT2 28.9 %
LONGFT2 25.0 %
RPM 725 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 97 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.560 V
SHRTFTB1S1 32.8 %
O2B1S2 0.170 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------74 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 45.9 %
ECT 181 °F
SHRTFT1 35.2 %
LONGFT1 24.2 %
SHRTFT2 37.5 %
LONGFT2 21.9 %
RPM 2366 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 97 °F
MAF 0.04 lb/s
TP 25.5 %
O2B1S1 0.055 V
SHRTFTB1S1 24.2 %
O2B1S2 0.150 V
SHRTFTB1S2 99.2 %
O2B2S1 0.720 V
SHRTFTB2S1 14.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------75 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.0 %
ECT 181 °F
SHRTFT1 20.3 %
LONGFT1 24.2 %
SHRTFT2 20.3 %
LONGFT2 22.7 %
RPM 2357 rpm
VSS 0 mph
SPARKADV 22.5 °
IAT 99 °F
MAF 0.04 lb/s
TP 25.5 %
O2B1S1 0.625 V
SHRTFTB1S1 18.8 %
O2B1S2 0.165 V
SHRTFTB1S2 99.2 %
O2B2S1 0.710 V
SHRTFTB2S1 25.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------76 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 181 °F
SHRTFT1 20.3 %
LONGFT1 24.2 %
SHRTFT2 24.2 %
LONGFT2 21.1 %
RPM 2541 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 100 °F
MAF 0.03 lb/s
TP 25.5 %
O2B1S1 0.755 V
SHRTFTB1S1 20.3 %
O2B1S2 0.175 V
SHRTFTB1S2 99.2 %
O2B2S1 0.065 V
SHRTFTB2S1 36.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------77 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 183 °F
SHRTFT1 19.5 %
LONGFT1 23.4 %
SHRTFT2 39.8 %
LONGFT2 21.9 %
RPM 2570 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.760 V
SHRTFTB1S1 6.3 %
O2B1S2 0.180 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 17.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------78 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 185 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 725 rpm
VSS 0 mph
SPARKADV 19.5 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.745 V
SHRTFTB1S1 14.1 %
O2B1S2 0.120 V
SHRTFTB1S2 99.2 %
O2B2S1 0.715 V
SHRTFTB2S1 18.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------79 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.8 %
ECT 185 °F
SHRTFT1 17.2 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 666 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.055 V
SHRTFTB1S1 23.4 %
O2B1S2 0.065 V
SHRTFTB1S2 99.2 %
O2B2S1 0.660 V
SHRTFTB2S1 32.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------80 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 187 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 616 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.065 V
SHRTFTB1S1 21.1 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 29.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------81 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.4 %
ECT 187 °F
SHRTFT1 29.7 %
LONGFT1 25.0 %
SHRTFT2 39.1 %
LONGFT2 25.0 %
RPM 703 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.765 V
SHRTFTB1S1 25.8 %
O2B1S2 0.105 V
SHRTFTB1S2 99.2 %
O2B2S1 0.800 V
SHRTFTB2S1 28.9 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------82 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.5 %
ECT 187 °F
SHRTFT1 18.0 %
LONGFT1 25.0 %
SHRTFT2 21.9 %
LONGFT2 25.0 %
RPM 707 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.070 V
SHRTFTB1S1 16.4 %
O2B1S2 0.780 V
SHRTFTB1S2 99.2 %
O2B2S1 0.705 V
SHRTFTB2S1 20.3 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------83 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.6 %
ECT 187 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 17.2 %
LONGFT2 25.0 %
RPM 719 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.770 V
SHRTFTB1S1 10.9 %
O2B1S2 0.845 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 14.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------84 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 42.4 %
ECT 185 °F
SHRTFT1 19.5 %
LONGFT1 24.2 %
SHRTFT2 11.7 %
LONGFT2 22.7 %
RPM 1786 rpm
VSS 0 mph
SPARKADV 20.5 °
IAT 102 °F
MAF 0.02 lb/s
TP 23.1 %
O2B1S1 0.710 V
SHRTFTB1S1 5.5 %
O2B1S2 0.835 V
SHRTFTB1S2 99.2 %
O2B2S1 0.055 V
SHRTFTB2S1 9.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------85 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 30.6 %
ECT 185 °F
SHRTFT1 9.4 %
LONGFT1 24.2 %
SHRTFT2 7.0 %
LONGFT2 21.9 %
RPM 2597 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 104 °F
MAF 0.03 lb/s
TP 25.5 %
O2B1S1 0.055 V
SHRTFTB1S1 -6.3 %
O2B1S2 0.835 V
SHRTFTB1S2 99.2 %
O2B2S1 0.680 V
SHRTFTB2S1 -11.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------86 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 31.8 %
ECT 183 °F
SHRTFT1 3.9 %
LONGFT1 24.2 %
SHRTFT2 -3.1 %
LONGFT2 0.0 %
RPM 3146 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 106 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.710 V
SHRTFTB1S1 -1.6 %
O2B1S2 0.205 V
SHRTFTB1S2 99.2 %
O2B2S1 0.035 V
SHRTFTB2S1 -2.3 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------87 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 41.2 %
ECT 185 °F
SHRTFT1 10.2 %
LONGFT1 25.0 %
SHRTFT2 14.8 %
LONGFT2 25.0 %
RPM 747 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 106 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.795 V
SHRTFTB1S1 18.0 %
O2B1S2 0.085 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 18.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
---------------------88 of 88 Frame---------------------
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 185 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 18.8 %
LONGFT2 25.0 %
RPM 674 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 106 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.060 V
SHRTFTB1S1 18.8 %
O2B1S2 0.135 V
SHRTFTB1S2 99.2 %
O2B2S1 0.615 V
SHRTFTB2S1 21.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
Those are my numbers for the scan tool, sorry so long, suggestions I have gotten so far are vacuum leak, failing fuel pump, bad o2 sensors, bad MAF.......so far replaced fuel filter and cleaned MAF.
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 37.6 %
ECT 183 °F
SHRTFT1 13.3 %
LONGFT1 25.0 %
SHRTFT2 18.8 %
LONGFT2 25.0 %
RPM 651 rpm
VSS 0 mph
SPARKADV 18.0 °
IAT 84 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.675 V
SHRTFTB1S1 14.1 %
O2B1S2 0.570 V
SHRTFTB1S2 99.2 %
O2B2S1 0.725 V
SHRTFTB2S1 17.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 183 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 14.8 %
LONGFT2 25.0 %
RPM 639 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 84 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.245 V
SHRTFTB1S1 12.5 %
O2B1S2 0.665 V
SHRTFTB1S2 99.2 %
O2B2S1 0.670 V
SHRTFTB2S1 14.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.8 %
ECT 183 °F
SHRTFT1 15.6 %
LONGFT1 25.0 %
SHRTFT2 22.7 %
LONGFT2 25.0 %
RPM 674 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.055 V
SHRTFTB1S1 21.9 %
O2B1S2 0.125 V
SHRTFTB1S2 99.2 %
O2B2S1 0.075 V
SHRTFTB2S1 29.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 183 °F
SHRTFT1 30.5 %
LONGFT1 25.0 %
SHRTFT2 36.7 %
LONGFT2 25.0 %
RPM 612 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.045 V
SHRTFTB1S1 35.9 %
O2B1S2 0.100 V
SHRTFTB1S2 99.2 %
O2B2S1 0.050 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.4 %
ECT 183 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 720 rpm
VSS 0 mph
SPARKADV 15.0 °
IAT 86 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.770 V
SHRTFTB1S1 35.9 %
O2B1S2 0.090 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.6 %
ECT 181 °F
SHRTFT1 27.3 %
LONGFT1 25.0 %
SHRTFT2 27.3 %
LONGFT2 25.0 %
RPM 962 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 88 °F
MAF 0.02 lb/s
TP 22.4 %
O2B1S1 0.770 V
SHRTFTB1S1 17.2 %
O2B1S2 0.135 V
SHRTFTB1S2 99.2 %
O2B2S1 0.500 V
SHRTFTB2S1 16.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 45.9 %
ECT 181 °F
SHRTFT1 18.8 %
LONGFT1 24.2 %
SHRTFT2 12.5 %
LONGFT2 24.2 %
RPM 1666 rpm
VSS 0 mph
SPARKADV 21.5 °
IAT 88 °F
MAF 0.02 lb/s
TP 23.1 %
O2B1S1 0.745 V
SHRTFTB1S1 6.3 %
O2B1S2 0.375 V
SHRTFTB1S2 99.2 %
O2B2S1 0.080 V
SHRTFTB2S1 14.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 43.9 %
ECT 180 °F
SHRTFT1 3.1 %
LONGFT1 24.2 %
SHRTFT2 11.7 %
LONGFT2 23.4 %
RPM 1848 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 88 °F
MAF 0.03 lb/s
TP 25.9 %
O2B1S1 0.080 V
SHRTFTB1S1 9.4 %
O2B1S2 0.735 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 3.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 34.5 %
ECT 180 °F
SHRTFT1 0.0 %
LONGFT1 23.4 %
SHRTFT2 -0.8 %
LONGFT2 22.7 %
RPM 2454 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 90 °F
MAF 0.03 lb/s
TP 25.1 %
O2B1S1 0.060 V
SHRTFTB1S1 -0.8 %
O2B1S2 0.705 V
SHRTFTB1S2 99.2 %
O2B2S1 0.610 V
SHRTFTB2S1 0.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 27.5 %
ECT 181 °F
SHRTFT1 7.8 %
LONGFT1 25.0 %
SHRTFT2 8.6 %
LONGFT2 25.0 %
RPM 753 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.025 V
SHRTFTB1S1 24.2 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.040 V
SHRTFTB2S1 30.5 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 181 °F
SHRTFT1 28.1 %
LONGFT1 25.0 %
SHRTFT2 34.4 %
LONGFT2 25.0 %
RPM 581 rpm
VSS 0 mph
SPARKADV 19.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.040 V
SHRTFTB1S1 35.2 %
O2B1S2 0.080 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.2 %
ECT 183 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 707 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.075 V
SHRTFTB1S1 42.2 %
O2B1S2 0.055 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 37.3 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 531 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.020 V
SHRTFTB1S1 42.2 %
O2B1S2 0.040 V
SHRTFTB1S2 99.2 %
O2B2S1 0.015 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.5 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 685 rpm
VSS 0 mph
SPARKADV 16.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.365 V
SHRTFTB1S1 39.1 %
O2B1S2 0.045 V
SHRTFTB1S2 99.2 %
O2B2S1 0.600 V
SHRTFTB2S1 39.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.0 %
ECT 185 °F
SHRTFT1 39.1 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 620 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 91 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.040 V
SHRTFTB1S1 42.2 %
O2B1S2 0.045 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 185 °F
SHRTFT1 42.2 %
LONGFT1 25.0 %
SHRTFT2 42.2 %
LONGFT2 25.0 %
RPM 718 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 91 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.750 V
SHRTFTB1S1 32.0 %
O2B1S2 0.080 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 34.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.8 %
ECT 185 °F
SHRTFT1 28.1 %
LONGFT1 25.0 %
SHRTFT2 32.8 %
LONGFT2 25.0 %
RPM 634 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.055 V
SHRTFTB1S1 29.7 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.785 V
SHRTFTB2S1 33.6 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.3 %
ECT 183 °F
SHRTFT1 21.9 %
LONGFT1 25.0 %
SHRTFT2 30.5 %
LONGFT2 25.0 %
RPM 656 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.040 V
SHRTFTB1S1 26.6 %
O2B1S2 0.130 V
SHRTFTB1S2 99.2 %
O2B2S1 0.040 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.0 %
ECT 185 °F
SHRTFT1 26.6 %
LONGFT1 25.0 %
SHRTFT2 30.5 %
LONGFT2 25.0 %
RPM 672 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.805 V
SHRTFTB1S1 20.3 %
O2B1S2 0.130 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 22.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.0 %
ECT 183 °F
SHRTFT1 14.1 %
LONGFT1 25.0 %
SHRTFT2 21.1 %
LONGFT2 25.0 %
RPM 694 rpm
VSS 0 mph
SPARKADV 18.0 °
IAT 93 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.065 V
SHRTFTB1S1 19.5 %
O2B1S2 0.600 V
SHRTFTB1S2 99.2 %
O2B2S1 0.660 V
SHRTFTB2S1 25.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.1 %
ECT 183 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 747 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 93 °F
MAF 0.08 lb/s
TP 30.2 %
O2B1S1 0.060 V
SHRTFTB1S1 42.2 %
O2B1S2 0.180 V
SHRTFTB1S2 99.2 %
O2B2S1 0.050 V
SHRTFTB2S1 42.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 183 °F
SHRTFT1 23.4 %
LONGFT1 25.0 %
SHRTFT2 28.9 %
LONGFT2 25.0 %
RPM 725 rpm
VSS 0 mph
SPARKADV 17.5 °
IAT 97 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.560 V
SHRTFTB1S1 32.8 %
O2B1S2 0.170 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 35.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 45.9 %
ECT 181 °F
SHRTFT1 35.2 %
LONGFT1 24.2 %
SHRTFT2 37.5 %
LONGFT2 21.9 %
RPM 2366 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 97 °F
MAF 0.04 lb/s
TP 25.5 %
O2B1S1 0.055 V
SHRTFTB1S1 24.2 %
O2B1S2 0.150 V
SHRTFTB1S2 99.2 %
O2B2S1 0.720 V
SHRTFTB2S1 14.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 38.0 %
ECT 181 °F
SHRTFT1 20.3 %
LONGFT1 24.2 %
SHRTFT2 20.3 %
LONGFT2 22.7 %
RPM 2357 rpm
VSS 0 mph
SPARKADV 22.5 °
IAT 99 °F
MAF 0.04 lb/s
TP 25.5 %
O2B1S1 0.625 V
SHRTFTB1S1 18.8 %
O2B1S2 0.165 V
SHRTFTB1S2 99.2 %
O2B2S1 0.710 V
SHRTFTB2S1 25.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 181 °F
SHRTFT1 20.3 %
LONGFT1 24.2 %
SHRTFT2 24.2 %
LONGFT2 21.1 %
RPM 2541 rpm
VSS 0 mph
SPARKADV 23.0 °
IAT 100 °F
MAF 0.03 lb/s
TP 25.5 %
O2B1S1 0.755 V
SHRTFTB1S1 20.3 %
O2B1S2 0.175 V
SHRTFTB1S2 99.2 %
O2B2S1 0.065 V
SHRTFTB2S1 36.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 183 °F
SHRTFT1 19.5 %
LONGFT1 23.4 %
SHRTFT2 39.8 %
LONGFT2 21.9 %
RPM 2570 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.760 V
SHRTFTB1S1 6.3 %
O2B1S2 0.180 V
SHRTFTB1S2 99.2 %
O2B2S1 0.025 V
SHRTFTB2S1 17.2 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 33.7 %
ECT 185 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 725 rpm
VSS 0 mph
SPARKADV 19.5 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.745 V
SHRTFTB1S1 14.1 %
O2B1S2 0.120 V
SHRTFTB1S2 99.2 %
O2B2S1 0.715 V
SHRTFTB2S1 18.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.8 %
ECT 185 °F
SHRTFT1 17.2 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 666 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.055 V
SHRTFTB1S1 23.4 %
O2B1S2 0.065 V
SHRTFTB1S2 99.2 %
O2B2S1 0.660 V
SHRTFTB2S1 32.0 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.9 %
ECT 187 °F
SHRTFT1 21.1 %
LONGFT1 25.0 %
SHRTFT2 25.0 %
LONGFT2 25.0 %
RPM 616 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.065 V
SHRTFTB1S1 21.1 %
O2B1S2 0.115 V
SHRTFTB1S2 99.2 %
O2B2S1 0.045 V
SHRTFTB2S1 29.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 40.4 %
ECT 187 °F
SHRTFT1 29.7 %
LONGFT1 25.0 %
SHRTFT2 39.1 %
LONGFT2 25.0 %
RPM 703 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.765 V
SHRTFTB1S1 25.8 %
O2B1S2 0.105 V
SHRTFTB1S2 99.2 %
O2B2S1 0.800 V
SHRTFTB2S1 28.9 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 36.5 %
ECT 187 °F
SHRTFT1 18.0 %
LONGFT1 25.0 %
SHRTFT2 21.9 %
LONGFT2 25.0 %
RPM 707 rpm
VSS 0 mph
SPARKADV 17.0 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.070 V
SHRTFTB1S1 16.4 %
O2B1S2 0.780 V
SHRTFTB1S2 99.2 %
O2B2S1 0.705 V
SHRTFTB2S1 20.3 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 39.6 %
ECT 187 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 17.2 %
LONGFT2 25.0 %
RPM 719 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 100 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.770 V
SHRTFTB1S1 10.9 %
O2B1S2 0.845 V
SHRTFTB1S2 99.2 %
O2B2S1 0.780 V
SHRTFTB2S1 14.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 42.4 %
ECT 185 °F
SHRTFT1 19.5 %
LONGFT1 24.2 %
SHRTFT2 11.7 %
LONGFT2 22.7 %
RPM 1786 rpm
VSS 0 mph
SPARKADV 20.5 °
IAT 102 °F
MAF 0.02 lb/s
TP 23.1 %
O2B1S1 0.710 V
SHRTFTB1S1 5.5 %
O2B1S2 0.835 V
SHRTFTB1S2 99.2 %
O2B2S1 0.055 V
SHRTFTB2S1 9.4 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 30.6 %
ECT 185 °F
SHRTFT1 9.4 %
LONGFT1 24.2 %
SHRTFT2 7.0 %
LONGFT2 21.9 %
RPM 2597 rpm
VSS 0 mph
SPARKADV 22.0 °
IAT 104 °F
MAF 0.03 lb/s
TP 25.5 %
O2B1S1 0.055 V
SHRTFTB1S1 -6.3 %
O2B1S2 0.835 V
SHRTFTB1S2 99.2 %
O2B2S1 0.680 V
SHRTFTB2S1 -11.7 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 31.8 %
ECT 183 °F
SHRTFT1 3.9 %
LONGFT1 24.2 %
SHRTFT2 -3.1 %
LONGFT2 0.0 %
RPM 3146 rpm
VSS 0 mph
SPARKADV 20.0 °
IAT 106 °F
MAF 0.01 lb/s
TP 18.8 %
O2B1S1 0.710 V
SHRTFTB1S1 -1.6 %
O2B1S2 0.205 V
SHRTFTB1S2 99.2 %
O2B2S1 0.035 V
SHRTFTB2S1 -2.3 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 41.2 %
ECT 185 °F
SHRTFT1 10.2 %
LONGFT1 25.0 %
SHRTFT2 14.8 %
LONGFT2 25.0 %
RPM 747 rpm
VSS 0 mph
SPARKADV 21.0 °
IAT 106 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.795 V
SHRTFTB1S1 18.0 %
O2B1S2 0.085 V
SHRTFTB1S2 99.2 %
O2B2S1 0.760 V
SHRTFTB2S1 18.8 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
DTC_CNT 0
FUELSYS1 CL
FUELSYS2 --
LOAD_PCT 35.7 %
ECT 185 °F
SHRTFT1 10.9 %
LONGFT1 25.0 %
SHRTFT2 18.8 %
LONGFT2 25.0 %
RPM 674 rpm
VSS 0 mph
SPARKADV 18.5 °
IAT 106 °F
MAF 0.01 lb/s
TP 19.2 %
O2B1S1 0.060 V
SHRTFTB1S1 18.8 %
O2B1S2 0.135 V
SHRTFTB1S2 99.2 %
O2B2S1 0.615 V
SHRTFTB2S1 21.1 %
O2B2S2 1.275 V
SHRTFTB2S2 99.2 %
OBDSUP OBDII
