97cv
- November 15, 2008
- 2001 Explorer Sport
A co-worker has an oil leak coming from the pass side of his engine.
The vacuum lines under the pass side of the PCV tube are a little wet.
The pass side/firewall valve cover is also a little wet.
From under the truck on pass side, You can clearly see oil running down the block.
Its a small leak that loks worse than it is, He doesnt need to add any oil since I changed it a week ago.But it is making its way down to the trans bell housing and the cats....So it looks like hell and smells too.
His PCV valve is functional.I checked its rattle and vacuum test too, It is however oily where it plugs into the PCV Vent tube that runs behind the engine.
I had asked him to join this site....He's a ******...Too busy watching sports !
Thanks in advance for your input and help.
