1Aauto
EF Vendor
- April 1, 2009
- mass
- 92 explorer
VISIT US HERE FOR GREAT PRICES 2002-2005 Ford Explorer 4 Door Front Upper Control Arm with Ball Joint Pair (excluding Sport Trac Models)
FREE SHIPPING IN THE LOWER 48 STATES!!!
These replacement front upper control arms are just what you need to bring back the safety and integrity of your vehicle's suspension and steering.
Specifications:
Comes as a PAIR
Fits both the LH (Driver Side) & RH (Passenger Side) FRONT UPPER
Replaces dealer part numbers: 1L2Z-3084-AA, 1L2Z-3085-AA, 1L24-3C263-AG, 1L2Z3084AA, 1L2Z3085AA, 1L243C263AG, MCS0E12, MCS0E13
Complete assemblies
Include ball joints, bushings, & upper shafts
Direct replacements
Built to strict quality control standards
Fit both 2WD & 4WD Models
Worn ball joints can cause excessive front tire wear, popping or creaking in the front end, extra play in the steering system, and pose a serious safety concern. Replace loose or worn ball joints with our quality replacements.
One way to diagnose a loose, or warn ball joint, is to jack the car up, so the wheel is off of the ground, then have someone try to move the wheel in and out. While they are moving the wheel check the ball joint for play, if it is moving you probably need to replace it.
Remember whenever you are replacing any front end or steering components you should have your vehicle professionally aligned as soon as possible. This will ensure proper tracking and even tire wear.
1A Auto Company Warranty
All parts are covered by a 60-day 1A Auto warranty against defects or failure. In the event of a part failure during intended use, we will exchange the part for the original purchaser at no cost and a pre-paid shipping label will be emailed to cover the cost of returning the defective part back to 1A Auto. Please keep your invoice for proof of this warranty.
Specifications:
Comes as a PAIR
Complete assemblies
Direct replacements
