KD9EAS
- July 26, 2015
- Indiana
Hi all, I searched and there is are so many threads close to this but none that seemed to nail my exact symptoms. None that I could find anyway. If I'm just repeating other's issues, could someone kindly point me in the direction of those threads?
My Explorer is a 2002 4 door 4WD Automatic V6. I think I'm nearing 100K miles on it. When I bought the vehicle, the 4WD was messed up, and the dealer replaced a good bit of the 4WD equipment, but I'm not sure what all was replaced. Vehicle has run fine for well over a year since.
Today, the transmission started acting up. When it goes to shift, it doesn't go into gear, but into a neutral state,(and will rev up high if I keep giving it gas). If I feather my foot on the pedal, it will find it's gear, sometimes clunking into it, shaking the Explorer. Occasionally I will start getting this whizzing noise like a small loud electric motor or a weed eater revving up whenever I step on the gas. The noise sounds like it could be coming from either the back of the engine bay or the transmission. After 3 or 4 times of giving it the gas, the noise will go away. A couple times so far the O/D light has started flashing, but I have yet to get a check engine light, and using a generic ODBII checker, I'm not getting any fault codes.
I typically don't change my fluids, I take it to the shop to have that done, but most work past that I usually do myself. I haven't had a chance to check the tranny fluid or have it checked yet. Anyone have an idea of where I should start troubleshooting?
