2002 ac/heat/vent problem
gglt
02 explorer
just replaced blend door actuator because I had no heat. when I got done ac doesn't work and mode selector doesn't work have hot air coming out of all vents. need help
Rick
Pumpkin Pilot
Staff member
Admin
Wayoutin, Aridzona
'93 XL Pumpkin Edition
Callsign
AB7FH
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
Welcome aboard!! :salute:
Did you follow the How To when you replaced the actuator?
How To: Replace Blend Door Actuator in 3rd Gen Ex
Pay close attention to step 7. Make sure that you test the actuator and that it is in sync with temp selctor:
Good luck getting it sorted. :thumbsup:
Please keep us posted as feedback helps others reading this post looking for a fix to the same or similar issue!
gglt
02 explorer
just got done taking it all apart again new actuator was bad didn't check it because it was new! learned a hard lesson get a new one tomorrow
BigRondo
USMC 1371
Moderator Emeritus
Worcester, MA
2002 XLT V6 4x4
It stinks that you have to do it twice. You should be a pro by the time you are done. :biggthump
gglt
02 explorer
It does but it sure went a lot quicker this time. Picking up new actuator after work
